1996 Palimino Pop up Truck Camper $1700 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2009, 08:40 PM   #1
farmergregman
Farmergregman
farmergregman's Avatar
Default 1996 Palimino Pop up Truck Camper $1700
1996 Palimino Bronco 1200 pop up truck camper. 1280 lbs. full loaded max weight. 18 gal fresh water tank, 30 amp DP panel w built in 12 v convertor, twin bed over cab, dinnette converts into second bed, three burner range, new 20 lb lp bottle with new style quick connect ( no wrenches needed)optional Dometic fridge ( just pluged in and very cold within a short time) optional Furnace with auto ignition, optional roof rack front and rear. used for canoe, all electrical works perfect, full fused wiring harness for truck battery, extra harness for bed battery if so desired. No water leaks, Just tested propane system, no leaks. always stored under roof since new, all fabric, windows, screens in excellent condition, optional 4th. jack leg. small
Thetford porta potti to set in aisle or on tail gate at night.
$1700.00
i have lots of pics but I have a hard time getting them to 900 by 900, all pictures taken 05/11/09 I am gonna continue to try and load them but do not wnt to loose this text so here it is. I can e-mail pictures much easier
farmergregman is offline   Reply With Quote
Old May 12th, 2009, 08:48 PM   #2
capone
capone's Avatar
Host the pictures through photobucket
capone is offline   Reply With Quote
Old May 12th, 2009, 09:01 PM   #3
farmergregman
Farmergregman
Default truck camper pictures
ID:	43296   Click image for larger version
ID:	43297   Click image for larger version
ID:	43298   Click image for larger version
ID:	43299   Click image for larger version
ID:	43301   Click image for larger version
ID:	43302   Click image for larger version
Old May 13th, 2009, 02:54 PM   #4
farmergregman
Farmergregman
Default more pictures of TC
extra pictures and also includes jack leg extensions for taller trucks.
ID:	43325   Click image for larger version
ID:	43326   Click image for larger version
ID:	43327   Click image for larger version
ID:	43328   Click image for larger version
Old May 14th, 2009, 09:43 PM   #5
farmergregman
Farmergregman
Default bump
bump why buy new for 3 times as much or more
Page generated in 0.19051 seconds with 39 queries
