Converter ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 11th, 2009, 11:50 PM   #1
Fraser
Fraser's Avatar
Default Converter ?
is there a difference between a 318 and a 360 converter? i have a former 360 truck and i got two bolts in the converter, and the other two dont line up. [318 was put in the place of the 360] 727 trans
Old May 12th, 2009, 08:25 AM   #2
Tom
Because racecar
Tom's Avatar
what year engines are you dealing with? Earlier 318/360 have differences with balancing the engines on the converter. Later 318/360 have different flex plates that are 90 and non 90
Old May 12th, 2009, 11:36 AM   #3
Fraser
Fraser's Avatar
motor is supposedly out of a 78 truck, this truck is an 82
Old May 12th, 2009, 12:04 PM   #4
Tom
Because racecar
Tom's Avatar
You are going to need a converter for a 318. If you run a 360 converter in a 318 or vise versa, you will have a bad engine vibration. The converter will only bolt up one way. You will have to turn it until all of the bolts lineup.
Old May 12th, 2009, 12:08 PM   #5
Fraser
Fraser's Avatar
ahh, ok. had a bad feeling that might be what it was
Old May 14th, 2009, 08:02 PM   #6
wilesin
10ptbuck
wilesin's Avatar
Two bolts are closer together than the others i think ive had this problem before keep rotating it and trying different holes.
wilesin is offline   Reply With Quote
Old May 14th, 2009, 08:11 PM   #7
jeepnxj96
jeepnxj96's Avatar
^^^^^^^^^^^^^^^^ what he said
Old May 16th, 2009, 11:57 AM   #8
Fraser
Fraser's Avatar
yup, gonna be tryin out that kinda thing soon not off by too much
Page generated in 0.39648 seconds with 47 queries
