proper method of strapping a vehicle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 8th, 2006, 10:32 PM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default proper method of strapping a vehicle
goin up to silver lake in 2weeks and i jsut bought me a trailer and im new to the hauling a jeep on a trailer..............i have 3 heavy duty ratchet straps for it as of right now and an axle strap.........how many straps should i use, and is the axle the best place to strap it down
BowtieWrangler is offline   Reply With Quote
Old June 8th, 2006, 10:42 PM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
I always use one strap per tire, around the axle. Make sure you have two straps pulling it forward, and two straps pulling it backwards so they stay tight.
Old June 8th, 2006, 11:16 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
i always go to the frame, i dont like to allow the vehical to bounce while on trailer. make sure you get the suspension to compress and dont skimp on tie downs..
use 2 up front and 2 out back criss cross them to the corner tie downs..
Old June 9th, 2006, 06:12 AM   #4
Paul04TJ
Small, but talented
Paul04TJ's Avatar
Bingo!
Paul04TJ is offline   Reply With Quote
Old June 9th, 2006, 07:52 AM   #5
Tie to the axles, not to sprung weight. 4 straps all pulling away from each other.
If you are one of those who don't like vehicle sway on your trailer, then use a couple smaller straps to tie down the body to the axles.
Old June 9th, 2006, 09:28 AM   #6
badazzamc
Get Some
badazzamc's Avatar
i always use 4 straps compression the suspension. i also angle the straps so they pull sideways on the jeep. it works for me i dont know if it is the correct way though.
Page generated in 1.18971 seconds with 41 queries
