WANT TO TRADE... 95 Camaro Lt1 53,711 miles heads,cam,intake - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 9th, 2009, 01:26 PM   #1
AKaraszewski
Default WANT TO TRADE... 95 Camaro Lt1 53,711 miles heads,cam,intake
I have a 95 Camaro Lt1 53,711 miles on the motor and a little over 93,000 on the body. It has comp cam 306 .540in .576ex 230in 244ex duration @ 112lsa, comp cam 1.6 pro magnum rockers, diamond racing 7.200 hardened push rods, csr electric water pump, crane cams dual springs good up to .610 lift, k&n cold air intake, harmonic damper, a/c delete but have the ac compressor still, 3.73 gears and rebuild kit in rear end2, 500 stall with shift kit, new brake pads, rotors, and lines, pacesetter long tubes with a custom x pipe into 2 spintech race mufflers, T/A rear end cover with studs, slp strut tower brace, gm lt4 heavy duty timing set, taller chevrolet valve covers, oem 2006 corvette wheels with brand new rear tires, ported heads, ported intake, eibach pro lowering springs, racetronix 255L fuel pump, ngk tr55 plugs with msd 8.5mm wires, newer optispark, large trans cooler,4 point roll cage, all new control arm bushings and swaybar links, 3.5 aluminum drive shaft, leather interior, t-tops and many other parts...motor and trans have 53.711 miles no bullshit....body is in pretty good shape a few minor dings.. All the car needs is to be tuned i had it tuned but they didnt do it right because the car wasnt there i just took the computer in. asking $5000 pretty firm since i could part it out and make 7000$ ....or trade for lifted TRUCK (preferably chevy) but let me know what you got...
586 218 0718
ID:	43072   Click image for larger version
ID:	43073   Click image for larger version
ID:	43074   Click image for larger version
ID:	43075   Click image for larger version
AKaraszewski is offline   Reply With Quote
Old May 9th, 2009, 01:37 PM   #2
badmag71
badmag71's Avatar
I have a 98 jeep cherokee xj with only 88,xxx original miles on itthat i was thinking about selling for around 5,000
badmag71 is offline   Reply With Quote
Old May 9th, 2009, 08:39 PM   #3
AKaraszewski
im looking for something lifted
Old May 10th, 2009, 08:28 AM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Hot. Best of luck in the sale!
@clarkstoncracker
Old May 10th, 2009, 04:59 PM   #5
donleybrent
donleybrent's Avatar
Send me some better pics of the outside please. donleybrent@yahoo.com
donleybrent is offline   Reply With Quote
Page generated in 0.21407 seconds with 39 queries
