How hard is it to change the axle seals? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 7th, 2009, 09:26 PM   #1
Freak
Wheelin the HD
Freak's Avatar
Default How hard is it to change the axle seals?
how hard is it going to be to change the front axle tube seals in my 1995 Ram 1500, Dana 44?
I'm guessing I have to pull the U joints, and knuckles, but how hard is it going to be to pull the shafts with the vacuum disconnects?
Old May 8th, 2009, 10:36 PM   #2
junk90xj
ALLPRO AUTO
junk90xj's Avatar
shafts just slide out. you will need to remove the vac disco housing to remove the shaft.
the pass side seal can be a pain in the arse to install but go slow and be easy it will go in.
http://www.apalansing.com/
Old May 13th, 2009, 01:36 PM   #3
Freak
Wheelin the HD
Freak's Avatar
thanks. haven't taken the time to really look close at this and just noticed after I changed the oil in the front diff that it was leaking out the tube seals on both sides... anything else I should think about replacing while its apart?
Old May 13th, 2009, 03:23 PM   #4
PavementPounder
PavementPounder's Avatar
The vacuum disco setup. Solid shaft.
Old May 13th, 2009, 03:26 PM   #5
Freak
Wheelin the HD
Freak's Avatar
hah, thanks, I was thinking chomoly or something, but I don't think I have the money for that.
Old May 13th, 2009, 03:58 PM   #6
PavementPounder
I just meant a regular solid shaft to eliminate the disco completely.
Old May 13th, 2009, 06:19 PM   #7
Freak
Wheelin the HD
Freak's Avatar
yah, I was looking at those, around $150... sounds like the place I worked for is getting ready to call back the drivers they laid off so it might be more feasible... going to have to see.
Old July 16th, 2009, 01:53 PM   #8
Millinski
Millinski's Avatar
What one pice shafts are available to do this. My buddy just called me asking if I can fix his front axle leak on a 99 Ram. From what I'm reading its a D44 and I'm guessing its his tube seals leaking but not sure till I see it. I'm familiar with this from Jeeps but dont have a clue with the Rams
Millinski is offline   Reply With Quote
Old July 16th, 2009, 10:26 PM   #9
Mclovin
"The Situation"
Mclovin's Avatar
be very careful installing the seal.. my old boss ruined about 3 seals before he borrowed the tool from the Chrysler dealer to install them properly
Old July 16th, 2009, 10:32 PM   #10
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
the tool is handy but not cheap. i have used a hammer and i dont suggest it
Trailrig is offline   Reply With Quote
Old July 16th, 2009, 10:46 PM   #11
boggin-machine
boggin-machine's Avatar
what is this special tool?
Old July 17th, 2009, 10:48 AM   #12
junk90xj
ALLPRO AUTO
junk90xj's Avatar
i made some cups to hold the seal in it on a lathe and then i have an adapter so i can use a real long extension and smack it in with a hammer.
Page generated in 0.45271 seconds with 59 queries
