What welder would you recommend? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2009, 06:27 PM   #1
Denton
Brush Yo Teeth!
Denton's Avatar
Default What welder would you recommend?
First off I have never welded before. I just want a welder to learn on and to do basic repairs on my vehicles and around the house. I do not really want to spend more than $200. What type would be best and what brand?
Thanks everyone!
Denton is offline   Reply With Quote
Old May 6th, 2009, 06:32 PM   #2
billycole
I would at least bump up the dollars to 300 and go for a 125 amp hobart handler. Just my opinion.
billycole is offline   Reply With Quote
Old May 6th, 2009, 06:44 PM   #3
redline8300
Redline8300
redline8300's Avatar
Lincoln 140C, I think that you can get one for the same price or so.
redline8300 is offline   Reply With Quote
Old May 6th, 2009, 06:49 PM   #4
firehawk
Live Action!
firehawk's Avatar
You can get some pretty good deals on Ebay.
I bought 2 Lincolns, one 175 and one 180 for about $400.
I know that is a little more than your budget but I was just posting it for reference.
The first two responses are good info too.
Old May 6th, 2009, 06:56 PM   #5
RustyRanger
Ford Fanatic
RustyRanger's Avatar
stick welder cheep to buy and cheep to use i payed 170 for mine + u can weld 16ga to 1/4 easy cant buy a migwelder that can do that for under 800$ without the co2 tank
RustyRanger is offline   Reply With Quote
Old May 6th, 2009, 07:05 PM   #6
rzmod
rzmod's Avatar
miller miller miller.....
rzmod is offline   Reply With Quote
Old May 6th, 2009, 07:44 PM   #7
1badzuk
1badzuk's Avatar
that cheap get hf 190 amp 110 welder
1badzuk is offline   Reply With Quote
Old May 6th, 2009, 08:00 PM   #8
billycole
Yes everyone will agree miller is the shit. Now show me a miller mig welder anywhere near $200
Old May 6th, 2009, 08:34 PM   #9
jeepxj2007
Send a message via AIM to jeepxj2007
So far my experience with welders are, you get what you pay for...maybe if you only need to use it once or twice get a cheapo, but if you are welding on something now and then spend the money and get something decent, I personally love millers, and I love both of the two that I have had, I have used many millers and they all worked great for me, plus they stand behind there product.
jeepxj2007 is offline   Reply With Quote
Old May 6th, 2009, 09:36 PM   #10
junk90xj
ALLPRO AUTO
junk90xj's Avatar
agreed with you get what u pay for.
anything by miller or lincoln are good chioces.
i see hobart has some cheap prices but the only hobarts i have used were 440v monsters
http://www.apalansing.com/
Old May 7th, 2009, 06:21 AM   #11
billycole
Hobart is millers cheaper brand my dad and myself have the 140 and have had no issues. The gun itself is miller and the replacement parts are miller part numbers.
Old May 7th, 2009, 12:58 PM   #12
computeruser
computeruser's Avatar
It may be a bit late, but HomeDepot was liquidating their Lincoln welders a while back when Lincoln changed to the more rounded faceplate profiles. As I recall, the 3200 was going for a couple hundred bucks with the gas regulator kit, and it will do single pass 3/16" with flux core easily, and runs on 110v (20A).
Might be worth looking around to see if any HD stores are still liquidating the old models...
computeruser is offline   Reply With Quote
Old May 7th, 2009, 01:14 PM   #13
steveo
In the band!
Miller is the best, but a handler is a good second option. hobart welders are basically millers, even some of the componets say miller. you can get a great entry level miller for about 500 and run tubular wire.
Old May 7th, 2009, 11:35 PM   #14
Arr-pea
Acceleration Junkie
Arr-pea's Avatar
I use a Miller 140 every day at work, it is dragged around on a cart up and down stairs. It takes a beating. The power supplys there sucks, so we have to use the .023 wire, C-25/75-AR gas, but it still does a great job. If you have to run it off much of an extension cord, make sure to use a larger gauge wire, that helps minimize the voltage drop to the welder. Great little welder. The 110v migs are great for being portable, the drawback is if you want to weld heavier Gauge steel 1/4 inch plus, you do not get the pentration like a 220V machine gets.
Arr-pea is offline   Reply With Quote
Old May 7th, 2009, 11:46 PM   #15
88mudder
In the band!
Id get aa Arc welder for the money you want to spend. If not then stick to a 110 Mig..it gets the job done but will not weld 1/4 very good. How thick of metals do you plan on welding?
Old May 8th, 2009, 12:32 PM   #16
jeepnxj96
jeepnxj96's Avatar
I have a Lincoln 175HD, it works nice and got it for 519 shipped to my door off of ebay, it was brand new. 185 for a bottle 40 for the gas and 26 for a 10lb spool of wire, and it is off to burning metal
Old May 11th, 2009, 09:52 PM   #17
Denton
Brush Yo Teeth!
Denton's Avatar
I just need to weld a motor mount bracket that snapped, a tailamp on my boat trailer and a couple spots on my exhaust
Old May 11th, 2009, 11:03 PM   #18
junk90xj
ALLPRO AUTO
junk90xj's Avatar
heck i could do all that for a fraction of what a welder costs.
Old May 12th, 2009, 08:43 AM   #19
steveo
In the band!
miller xmt 304
Old May 12th, 2009, 09:53 PM   #20
Take a drive
http://detroit.craigslist.org/tls/1167817784.html
Nothing spectactular, but a solid little welder. I used one of these for 6 years, build 4 vehicles with it. Run it with flux core, for better penetration.
Page generated in 0.39734 seconds with 83 queries
