95 F150 tranny problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2009, 06:02 PM   #1
wildbill4770
Web Wheelin at its finest
wildbill4770's Avatar
Default 95 F150 tranny problems
4.9L manual trans think its shot. Could be the transfer case but most likley the trans. Any one know what trans i need and does anyone have one cheap?? Basically start it and put it in gear and nothing happens. Go from that thanks
Got it running horrible winding noise coming from under vehicle sounds like t case put the t case in neutral and noise stops with tranny in gear and running
wildbill4770 is offline   Reply With Quote
Old May 7th, 2009, 02:00 PM   #2
wildbill4770
bump
Old May 7th, 2009, 04:15 PM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
its a mazda M50D-R2
Old May 7th, 2009, 05:04 PM   #4
wildbill4770
dealer said it had a mazda 5 speed in it i haven't personally done anything to this truck the only info i have is what the people selling it tell me 4.9liter 5 speed manual
Old May 7th, 2009, 08:43 PM   #5
blownexploder94
Todd
blownexploder94's Avatar
Guessing maybe the clutch is shot? just a guess
Old May 8th, 2009, 06:08 PM   #6
wildbill4770
anyone else have any ideas
Old May 8th, 2009, 07:55 PM   #7
wildbill4770
bump
Old May 9th, 2009, 02:57 PM   #8
camccardell
tiger blood
camccardell's Avatar
pull the t case and split it man.
if the chain is stillin 1 piece then it is the tranny, if there are tons of scrap metal shards, you have found your problem.
Old May 9th, 2009, 03:26 PM   #9
Nuggets
I fix stuff!
Nuggets's Avatar
x2
Old May 11th, 2009, 03:25 PM   #10
wildbill4770
pulled the t-case off and the shafts that connect the trannny to the case are all stripped something horrible happened so i think i also need a tranny already picked up a cheap t case over the weekend
Old May 11th, 2009, 11:02 PM   #11
camccardell
tiger blood
post pics man, i wanna see.
and split the t case too
Old May 11th, 2009, 11:07 PM   #12
Bishop
Bishop's Avatar
i dont want to sound like a dick but thats kinda funny
Old May 12th, 2009, 03:54 PM   #13
wildbill4770
glad i could make you laugh
Old May 15th, 2009, 02:52 PM   #14
wildbill4770
bought a different t-case and took the tranny to the shop and the output shaft was completley stripped of all its splines but the rest of the trans was ok. getting new bearings and brass put in it shaft was expensive but was unable to find a used replacement. when i can i will look inside the t-case to see if anything exploded inside pictures sometime
Page generated in 0.29591 seconds with 65 queries
