Ranger Bumper - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 4th, 2009, 09:51 PM   #1
jeepxj2007
Send a message via AIM to jeepxj2007
Default Ranger Bumper
Check out my bumper I built for my 93 ranger and let me know what you think. I started out with 5x5 1/4 wall square tube, cut it to 5'. Cut out the angles with a 4 1/2" cutoff wheel and cut plate to fit, welded it in, used 2.5x2.5 1/4 wall for the receiver in the center, and on the inside I welded 2h heavy nuts for tow hooks for lighter pulls, and hella lights, used 3" channel for the mounts and gusseted it to the bumper for extra strength, as far as mounting it I am going to take some 1/4" plate drill 3 1/2" holes through it, weld 3 pieces of 1/2" sch 80 pipe as crush sleeves that will go through the frame and weld to the opposite side of the frame rail so a 1/2" bolt can go through each, I'm thinking a 3"x4" piece and that would be welded to the frame plus the pipe to the opposite side, hopefully that will be strong enough, the stock mounts were bent from the tow hooks being mounted to it. Well what do you think of it? I am going to herculine it and then paint it a gray color.
jeepxj2007 is offline   Reply With Quote
Old June 14th, 2009, 07:53 AM   #2
55.0.0
Default rear bumper
Do you still have the bumper & if still do I have 87 ranger what is the inside measurement?
55.0.0 is offline   Reply With Quote
Page generated in 0.21989 seconds with 29 queries
