fuel pump help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2009, 01:26 AM   #1
19914x4blazer
ps4 tag chevytruckguy82
19914x4blazer's Avatar
Default fuel pump help
ok i got this sami and it will not start. i know that i have no fuel coming in and i check the pump. i got no power at the pump and now i check the relay and i got power befor it . so i get new relay and now i have power at the pump. but it wont come on. the guy i got it from said he put a 1.6l in it. what fuel pump do i look for? i see on here it said an f150 but what year and what motor? would it be better to just get one from a tracker?
thanks mike
19914x4blazer is offline   Reply With Quote
Old April 30th, 2009, 07:21 AM   #2
93trackaddict
93trackaddict's Avatar
Default pump
does the tracker motor still have the ecm, you might want to look there.
93trackaddict is offline   Reply With Quote
Old April 30th, 2009, 06:47 PM   #3
scottie
Eye candy
scottie's Avatar
a lot of people have the external ford fuel pump. I think its an E2000 from AZ or similar.
It fits an 86 Marquis with the 3.8L. They are from the fords that run an intank pump and an external pump. Which i think is pretty common for any late 80's ford with FI that has a larger engine or a turbo.
and tracker ones are intank, expensive, and you have to modify them to get them to fit inside a Samurai tank. YOu could probably buy a FI Samurai pump, but $$$$$$$$$
Old April 30th, 2009, 08:17 PM   #4
spazbrevik
You might want to pull the pump from the tank and hook your power right to the pump. I have heard of the connectors on top of the tank rusting and not transferring the power down to the pump. You may still have a good pump with a faulty connection.
spazbrevik is offline   Reply With Quote
Old April 30th, 2009, 09:52 PM   #5
19914x4blazer
i am not sure how would i tell ?
spazbrevik i did that and still no go
Old April 30th, 2009, 11:20 PM   #6
scottie
Eye candy
scottie's Avatar
have you tried hooking 12 v up to the pump and seeing if it runs?
Old April 30th, 2009, 11:32 PM   #7
19914x4blazer
yes i did that and still nothing. i am trying to find a pump for it to see how much its going to be
Old May 3rd, 2009, 12:14 PM   #8
A4X4SPIT
A4X4SPIT's Avatar
you have power at the fuel pump that runs about 3seconds when you first turn the key on? if so another thing to check is the ground to the pump..
A4X4SPIT is offline   Reply With Quote
Old May 3rd, 2009, 08:28 PM   #9
scottie
Eye candy
scottie's Avatar
did you figure it out yet?
Old May 5th, 2009, 06:28 PM   #10
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
On my samurai I just put an aftermarket MSD in-line fuel pump on it. cost me about $110 and it ran great. I priced the stock fuel pump from auto zone and it was like $450 but this was like a year or two ago.
Old May 5th, 2009, 09:25 PM   #11
19914x4blazer
not yet i am still waiting to get paid on friday (i get paid every 2 weeks) when i do i am going to get a new pump
if i get an in-line fuel pump how does that go on? do i just put in in and it pulls the gas throught the old in tank pump or do i need to do something \ rig something to get it to work?
Old May 5th, 2009, 10:30 PM   #12
scottie
Eye candy
scottie's Avatar
so you have an intank pump now?
I don't know much about the suzuki intank pumps. On mine i just run the inline pump with the factory pickup (in carb form).
You might want to check around on Zuwharrie and see if someone will ship you a Samurai intank pump if you are still running a Samurai tank.
Old May 5th, 2009, 11:48 PM   #13
19914x4blazer
yes i do have a intank pump now .i do have the Samurai tank but it has a tracker in tank pump. the guy i got it from put the 1.6l in it and put a intank pump from a tracker in it.
Old May 6th, 2009, 07:10 AM   #14
A4X4SPIT
A4X4SPIT's Avatar
if you have a intank pump you probably will not want to suck gas thru it with a external pump you may want to remove it or if the tank has original pick up still intackt use that.
I had a similar problem & was going to do the external pump & when I took out the pump & banged it with a hammer it started working so we ran some liquid pb blaster thru it &put it back in & its still working 2 years later & I know another guy who did same thing& his is working too might be worth a try if youy have to remove tank any way
Old May 6th, 2009, 10:15 PM   #15
19914x4blazer
that did not work. so i take the old pump out put the inline on and it just works like the one intank?
Old May 7th, 2009, 10:07 AM   #16
A4X4SPIT
A4X4SPIT's Avatar
you may have to add onto the fuel pickup to replace where fuelpump was then mount external fuel pump as close to tank as possible
Old May 7th, 2009, 10:12 AM   #17
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
The in tank fuel pump will allow fuel to be pulled through without having to remove it. The Ford E2000 pump is the frame mounted pump from an '89 Ranger or Bronco II. The most common place for mounting is attaching it to the little skid plate that covers the rear proportioning valve for the brakes, directly upstream from the factory fuel filter. Cut the power line from the factory harness, (pink with black tracer) and hook it up to the power side of the new pump, and ground the other side real good. The Ranger pumps can handle the rigors of off roading better than the Grand Marquis pump, slight design difference. You need a pump that outputs ~ 45 PSI to keep the fuel injection happy on the engine. If you are running a carb, what the hell is wrong with you?. Regular 5/16 reinforced gasoline hose with ideal clamps will harness the fuel pressure fine, and with the sock on the bottom of the in-tank pickup, and the factory fuel filter you are set to run.
zook94 is offline   Reply With Quote
Old May 7th, 2009, 09:23 PM   #18
scottie
Eye candy
scottie's Avatar
hmm i'm wondering if he applied 12V to the fuel level sender now.
Old May 7th, 2009, 09:39 PM   #19
Nuggets
I fix stuff!
Nuggets's Avatar
The fuel pump should have heavier gauge wire than the sending unit. Have a friend help you when checking power at the pump. Attach a test light to a known good ground. Probe the power wire to the fuel pump while your friend turns the key on. The test light should light for about two seconds. If that works, probe the ground wire the same way while your friend turns the key on. If it lights up you have a ground problem, if it doesn't light up you have either a bad pump or a break in the wires going to the pump from the connector at the top of the tank.
Old May 8th, 2009, 12:12 AM   #20
19914x4blazer
ok i got a new tracker intank pump today and she starts right up thanks for all the help
Page generated in 0.29756 seconds with 83 queries
