Project: YJ Myth - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 29th, 2009, 08:58 AM   #1
brandonjb
YJ enthusiast
brandonjb's Avatar
Send a message via MSN to brandonjb Send a message via Yahoo to brandonjb
Default Project: YJ Myth
This is my 1990 YJ that I have done a complete frame off. It started with a massive rust hole in the frame and I just kept going lol.
Here is what I put in it so far:
1990 Camaro 305ci engine 45k Miles
Rebuilt Holley carb
SOA
Rebuilt 700r4 out of a full size chevy pickup
NP 241C Transfer case out of a full size chevy pickup
D44 (Rebuilt) with flat top knuckles and high steer
8.8 (Rebuilt) 31 Spline 4:11 Explorer rear axle
Poly gas tank and all new high pressure lines
Summit Aluminium Radiator
Durabacked floor and underside of body
I bet someone is going to ask, why the frick would I put a 305 in it!? Simple answer: gas mileage. I'm building this as a daily driver and a trail rig, trying to get a good blend of both. Thats also why I used the 700r4, cuz it has over drive =)
Oh my it's my rear (8.8 not in at this point)
Here is that lovely poly tank I got for 75 bucks, god I love craigslist lol
I was testing the fit of the front clip, and checking tire clearence... I need bigger tires lol
brandonjb is offline   Reply With Quote
Old April 29th, 2009, 12:45 PM   #2
brandonjb
YJ enthusiast
brandonjb's Avatar
I decided to use this old bump to add more pics =)
I took this pic after I installed my Summit Aluminium Radiator, it has carboard on it.
Because it will be a daily driver, I decided to make a set of track bar discos... they turned out awesome, just spin a bolt, pull a pin and the track bar breaks into 2 seperate pieces =).
Old April 29th, 2009, 12:47 PM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
why would you put a 305 in there?
Old April 29th, 2009, 12:55 PM   #4
brandonjb
YJ enthusiast
brandonjb's Avatar
Well for a host reason's. Mostly because a 305 with 45k miles on it fell into my lap. Complete from malifold to oil pan. But I have always liked the idea because there good on gas, and back then gas was 4+ buck a gallon. I did however remove all of the nasty emissions stuff off it. On the trail it won't have gobs of power but it will take me a really long way lol.
Old April 29th, 2009, 12:57 PM   #5
Tom
Because racecar
Tom's Avatar
because 305 > 350 TPI with a FPR Knock
Old April 29th, 2009, 12:59 PM   #6
brandonjb
YJ enthusiast
brandonjb's Avatar
I'm sorry what does FPR mean?
Old April 29th, 2009, 01:00 PM   #7
clarkstoncracker
lol
if you look at a camaro with a 305 vs a camaro with a 350, they both get exactly 17 mpg from the factory.
Old April 29th, 2009, 01:00 PM   #8
howell_jeep
Last Free Man
howell_jeep's Avatar
Looks nice!
I SHOOT RAW!
Exercise your rights! Open Carry!
howell_jeep is offline   Reply With Quote
Old April 29th, 2009, 01:00 PM   #9
What kind of fuel pump?
Old April 29th, 2009, 01:02 PM   #10
brandonjb
YJ enthusiast
brandonjb's Avatar
HP aftermarket mechanical fuel pump
Old April 29th, 2009, 01:02 PM   #11
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
What front axle are you gonna use? I think you should convert it to TTB from the explorer you got the rear axle out of that sure would make it one of a Kind.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old April 29th, 2009, 01:02 PM   #12
Pokerob
hug life
Pokerob's Avatar
305 > 2.5 > 350 TPI with a FPR Knock
Old April 29th, 2009, 01:03 PM   #13
brandonjb
YJ enthusiast
brandonjb's Avatar
For now I am going to run the d30 on the front because I'm running out of cash and I still need a SYE and a rear drive shaft, plus an interior lol
I only bought the 8.8 from a friend, he did'nt have the entire explorer
Old April 29th, 2009, 01:04 PM   #14
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Why lift it if you want good gas mileage? They suck for mileage stock then you put a V8 in it and lift it?
Old April 29th, 2009, 01:04 PM   #15
clarkstoncracker
lol
I see his engine is definitly MAF which leads to believe the MFW will probably BRB. lol
Old April 29th, 2009, 01:05 PM   #16
Tom
Because racecar
Tom's Avatar
stop hatin' CC The real reason he is using a 305 is that he wants to use 100% throttle instead of 15% like yourself
bump
Old April 29th, 2009, 01:05 PM   #17
Fatty Matty
Fatty Matty's Avatar
Why the 700r4?
'12 JKU
'14 1500
www.midwest-abs.com
Old April 29th, 2009, 01:07 PM   #18
brandonjb
YJ enthusiast
brandonjb's Avatar
Omg the only thing I understood there is BRB what does MAF and MFW mean lol?
Old April 29th, 2009, 01:08 PM   #19
brandonjb
YJ enthusiast
brandonjb's Avatar
Originally Posted by Fatty Matty View Post
Why the 700r4?
Well this choice was mostly because I used the transfer case/ trans and the factory adapter for a full size chevy pickup. So it was cheap this way and all the shafts worked. No aftermarket adapters or shafts needed =)
and to save gas, it has overdrive after all.
Old April 29th, 2009, 01:09 PM   #20
clarkstoncracker
lol
Why the 700r4?
This build is to save gas, he obviously wanted the overdrive.
Page generated in 1.11943 seconds with 83 queries
