just bought a boat, motor ?????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2009, 08:40 PM   #1
mudrunner456
mudrunner456's Avatar
Default just bought a boat, motor ??????
Just brought home a boat brother in law said i could have. Its a 19 foot bayliner with a 125 horse force engine. Dont know much about boats at all. Said it ran awsome when parked four years ago and now im wondering what i should do before i try and start it. already planning to change out the gas battery and oil. what else complete tear down?
mudrunner456 is offline   Reply With Quote
Old April 28th, 2009, 09:07 PM   #2
Bones
Bones's Avatar
take the carbs off and shoot carb cleaner in every port while cycling the butterfly valves.
clean all fuel and oil lines
drain all fuel and oil and replace.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 28th, 2009, 09:38 PM   #3
mudrunner456
thanks for thes advice im hoping to get it goin cause the boat itself is still really nice
Old April 28th, 2009, 09:41 PM   #4
Denton
Brush Yo Teeth!
Denton's Avatar
make sure to drain the lower unit lube and replace.
Denton is offline   Reply With Quote
Old April 28th, 2009, 09:45 PM   #5
mudrunner456
This is different than the motor oil??
Old April 28th, 2009, 09:49 PM   #6
Denton
Brush Yo Teeth!
Denton's Avatar
yes. It is on the outdrive. It should have 2 slotted plugs. one upper and one lower. Take both off and drain. Then fill with lower unit lube from the bottom plug hole until it runs out the top plug hole.
Old April 29th, 2009, 08:29 AM   #7
Petsan
GLFWDA UFWDA
Petsan's Avatar
When you get it started make sure water is coming out of the exhaust, if not don't let run to long.
Petsan is offline   Reply With Quote
Old April 30th, 2009, 04:46 PM   #8
sabastian
how much money do you have? jeeps are expensive, but in my opinion, boats are more. so much fun though. you'll love it.
here are some things you may want to look at as well.
1. when replacing the outdrive oil (as explained in a previous post) make sure it's clean, if milky, you have other problems. a boat sitting that long will have old deteriorated parts. especially on the out site...like at the out drive. you may need to replace all the rubber boots on the out drive.
2. change spark plugs. get the model number from a boat store and buy them some where else. much cheaper.
3. change the oil filter, fuel filter, and water seperator if equiped.
4. if you don't know how to rebuild your carb, you may want to have it serviced. should be around 175 bucks.
5. check all electrical to make sure it's not all corroded. replace and clean terminal ends if they're bad.
6. check to make sure everything works like the bilge pump, navigation lights, blower, horn, ect...
7. if you plan on putting it in the water this year, get a safety check list together and equip your boat with all that crap. waste? maybe, but police do random stops to make sure you have all that shit on board.
8. make sure trailer lights work good.
9 clean it up, wax it and have fun.
sabastian is offline   Reply With Quote
Old April 30th, 2009, 04:59 PM   #9
hondadirtracer
Skymaster
hondadirtracer's Avatar
got any pictures of the boat?
hondadirtracer is offline   Reply With Quote
Old April 30th, 2009, 05:00 PM   #10
kickstand
circling the drain
kickstand's Avatar
assuming your 125 force is a two stroke outboard motor then yeah, the lower unit lube is different than the motor oil.
assuming it's a 2 stroke outboard (it should be)
1. change lower unit oil
2. New plugs
3. New gas
4. run some sort of fuel system cleaner through it, I suggest quicksilver quick kleen
let er eat
Old April 30th, 2009, 05:01 PM   #11
mudrunner456
very helpful list, thank you. I plan on working on it this weekend. I think i should be able to handle all of those things. What kind of oil goes in the outdrive and were do i get it?
Old April 30th, 2009, 05:03 PM   #12
mudrunner456
after this weekend and i get a chance to clean it up a bit. It had a good cover on it all this time but still could stand a wash.
Old April 30th, 2009, 08:32 PM   #13
Bones
Bones's Avatar
better yet, get a water pressure gauge. My Merc runs for 45 secs (on muffs)or so before it starts pissing out the telltale hole, and even then, it's just a dribble at idle
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 25th, 2009, 11:56 AM   #14
mudrunner456
just finally got it to run, been busy with my truck broke down so it got pushed aside. It fired right up after i changed all the fluids and stuff. But no water out of exhaust what is the longest i should let it run before i shut it down. Could it really take up to 45 sec. or more. This is in the driveway with muffs.
Old May 25th, 2009, 12:02 PM   #15
mudrunner456
So far i got $300 into it including buying it.
Old May 25th, 2009, 02:36 PM   #16
peppy
Looks good.
peppy is offline   Reply With Quote
Old May 25th, 2009, 07:21 PM   #17
Petsan
GLFWDA UFWDA
Petsan's Avatar
I would say that the impeller in the lower unit is bad, it is not big job to change and it cost maybe $50 for the pump and housing.
Page generated in 0.42320 seconds with 74 queries
