welder settings - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2009, 07:10 PM   #1
dingle dave
PARTS SLINGER
dingle dave's Avatar
Default welder settings
i just bought a miller 210 mig welder and was wondering what everyone suggested i should use for wire size, what my flow should be set at and any other detailed info would help. I realize you can only get me in the ballpark but any help would be appreciated. I'll be starting off welding .120 wall dom tube. I know there are some pro's on here that can help.
dingle dave is offline   Reply With Quote
Old April 28th, 2009, 07:30 PM   #2
jhnyquest
goof ball
jhnyquest's Avatar
Wire size .030 or more likely .035. Flow settings for gas approx 20-25psi.
Old April 28th, 2009, 07:31 PM   #3
cmays03
BUILD BY ME NOT BOUGHT!
you can get away with .030 or .035 wire. as for the settings. that depends on the sire you go with but i would say to test it out on scrap pieces. there should be a chart with the welder. most of them are on the inside of the panel for the wire.
cmays03 is offline   Reply With Quote
Old April 28th, 2009, 07:31 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Let me ask what it came with? and if your using Gas or Flux core?
Yetti
Old April 28th, 2009, 08:45 PM   #5
dingle dave
PARTS SLINGER
sheilding gas for suretired of breathing the flux in. Its got a spool of .035 lincoln wire in it. I have the flow set at 20 and it seems like its not getting enough gas. Welds look like they are dark. Upped the gas to 35 and it doesn't seem any better????
Old April 28th, 2009, 08:53 PM   #6
boggin-machine
boggin-machine's Avatar
is the tip clean? is the nozzle adjusted right? what gas are you running?
Old April 28th, 2009, 09:02 PM   #7
jeepnxj96
jeepnxj96's Avatar
I was running my Lincoln at ~25-30 cfh which is friggin way to much and wasn't getting real good welds, so I took the gun loose from the welder and took the gun apart to see if something was hindering my gas flow and what I found I believe is that the set screw that holds the end of the gun cable in the welder was loose allowing the insert to move back and forth and not get a good ground either, the gas was leaking from the double o-rings.
point to all that is after I fixed the problem my gas setting is now at ~10-12 cfh, which is where it is supposed to be. with my welder (Lincoln 175 HD) I can weld sch 40 pipe on the middle setting and feel confident I am getting good penetration (fillet weld)
hope that helps.
Old April 28th, 2009, 09:07 PM   #8
dingle dave
PARTS SLINGER
using 75/25 gas. I'll check my gun and tips out tommorrow and see if i find any problems.
Old April 28th, 2009, 10:01 PM   #9
cmays03
yeah you should only have to run 10-15 for the gas. thats all i ever ran in any welders i have used and that was at work welding heavy steel.
Old April 29th, 2009, 07:11 AM   #10
fsumotorhead
N8KVB
fsumotorhead's Avatar
I have mine set at 20 cf/hr. I can't remember where i found this spec at, but i thought it said not to lower the flow below 20.
You are welding out of the wind right?
Old April 29th, 2009, 07:16 AM   #11
fsumotorhead
N8KVB
i just found this on google, should help get you going
http://www.millerwelds.com/resources...calculator.php
Old April 29th, 2009, 07:22 AM   #12
fenderphilsy
freaking jeep
fenderphilsy's Avatar
Default welding tip
when you are welding it should sound like frying bacon,gas 25 to 35 psi
as for the wire dont really matter to much on the size depends on what the thickness of the metal you are welding and on how hot you are running the welder. just make sure you check the rollers and use the groves for the size wire most welders have 2 different size groves on the rollers.
fenderphilsy is offline   Reply With Quote
Old April 29th, 2009, 12:45 PM   #13
jmdzuk
jmdzuk's Avatar
25-35 PSI ! ???
its flow not preasure and 10-15 cfh is more than enough. if you need more do to wind or draft ,block it with something.
And dont buy you wire from TSC or any other off brand bulk supplier its crap from China.
I switched over strictly to Lincoln consumables wire ect.and will not switch back.
Miller stuff is just as good I just like red :)
Jeff
jmdzuk is offline   Reply With Quote
Old April 29th, 2009, 01:45 PM   #14
95geo
newbie
95geo's Avatar
Originally Posted by jmdzuk View Post
25-35 PSI ! ??? its flow not preasure and 10-15 cfh is more than enough. if you need more do to wind or draft ,block it with something.
Jeff
I weld .120" tube on 100-125 amps with .030" wire and about 20 CF (something... hour, minute... whatever it is). I actually prefer to use the TSC wire over any other wire I have used and I've gotten wire from just about everywhere... Ask Benny87 what he thinks of the TSC wire... he just switched to it, he said it was night and day. When I get a bad spool from TSC I'll continue the search for the "good" wire.
Old April 29th, 2009, 06:44 PM   #15
Jasper_Jpr
Northwest Ohio Crawlers
Jasper_Jpr's Avatar
Lincoln Wire spec Direct From Lincoln Site
SuperArc L-56
AWS ER70S-6
Diameter (in) .035
Diameter (mm) 0.9
Package 30 lb. Plastic Spool
Product Number ED016099
Typical Application
For welding on base material that has medium to heavy millscale.
Automotive repair.
Sheetmetal to multiple pass applications on 55,000 to 70,000 psi (379 to 483 MPa) yield strength base metal.
Conformance
AWS A5.18: ER70S-6
ASME SFA-5.18: ER70S-6
MIL-E-23765/1: MIL-70S-6
CWB W48-01: ER49S-6
Shielding Gas
100% CO2
75-95% Ar / Balance CO2
95-98% Ar / Balance O2
Flow Rate: 30 - 50 CFH
Jasper_Jpr is offline   Reply With Quote
Old April 29th, 2009, 08:21 PM   #16
jeepnxj96
jeepnxj96's Avatar
at those flow rates a Q size bottle of gas won't make it through a 10lb spool of wire, 8-12 CFH is all the gas flow you will need, it is mig welding not TIG
Old April 29th, 2009, 08:57 PM   #17
jmdzuk
jmdzuk's Avatar
I got a bad spool.... plus I get much better life out of my liners and contact tips ect..
I use L56 and L50 .The L56 is much more fluid than the L50 .The L50 is better penetrating just not as many scavengers in it ect..
TSC wire is from China.
Everyone has there preferences
Good luck
Old May 1st, 2009, 12:44 PM   #18
DUNE JUMP
DUNE JUMP's Avatar
I'll trade you straight accross for my well-dialed-in Lincoln Pro-Mig 135
Old May 1st, 2009, 12:59 PM   #19
Trailrig
Hoggin'-N-Boggin'
Trailrig's Avatar
Send a message via AIM to Trailrig
listen for the bacon frying and you should be close
Trailrig is offline   Reply With Quote
Old May 1st, 2009, 06:56 PM   #20
jeepnxj96
jeepnxj96's Avatar
listening is good, but you can also see it as well, watch the arc, you can tell if it is making a good weld or not, if the arc is jumping back and forth from the work piece towards the tip and making an irrattical sound adjust your wire speed if the the heat setting is correct. you can also see the puddle forming in front of the wire being fed, can be adjusted by heat and feed of the gun. It takes getting used to your welder, take some scrap and try out a couple beads, you'll find the sweet spot. every welder is different.
Page generated in 0.51417 seconds with 83 queries
