Nissan LD28, 2.8L 6-cylinder diesel for sale - ***No longer available*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2009, 06:53 AM   #1
RAVC1
RAVC1's Avatar
Default Nissan LD28, 2.8L 6-cylinder diesel for sale - ***No longer available***
I have an LD28 diesel engine from a 1981-1983 Nissan 810 that I purchased to transplant into my 1989 XJ. This includes the complete induction system, exhaust manifold, starter, alternator & vacuum pump, and A/C compressor. This is about 90 hp with 40+ mpg fuel economy. I do not have the torque output of this engine memorized.
Sold as a complete package only; $1500.
Thanks,
Rick
Last edited by RAVC1; December 31st, 2011 at 06:20 AM. Reason: No longer for sale - I'm preparing to use this.
RAVC1 is offline
Old May 1st, 2009, 09:53 PM   #2
RAVC1
RAVC1's Avatar
Default Re: Nissan LD28...
Better bump...
RAVC1 is offline
Old May 10th, 2009, 11:48 AM   #3
RAVC1
RAVC1's Avatar
Bump #2
RAVC1 is offline
Old May 10th, 2009, 06:21 PM   #4
jeepers48
jeepers48's Avatar
Turbo or non-turbo and does it come with a trans?.....case? How many miles are on the motor?
jeepers48 is offline
Old May 11th, 2009, 09:08 PM   #5
RAVC1
RAVC1's Avatar
Default Re: LD28...
Jeepers48,
The LD28 is naturally aspirated. I do not think Nissan ever turbocharged this engine but I only know it as used in the 810. If you are genuinely interested in turbocharging you might want to look for a used copy of Hugh MacInnes book(s) or possibly Corky Bell's book. A low pressure turbo charger would be useful for fuel economy gains and reduce engine noise because it would close the intake/exhaust path. However, this would require removal of at least 1 mm/.039" from the piston crown because this is an indirect injection diesel engine. In turn, the geometric compression ratio is ~21:1-22:1. You would want to reduce this to ~16:1 or 17:1 with turbo charging to prevent from melting pistons.
No transmission or transfer case. I have seen both automatic and the 5-speed manual as well as the transfer case that mates directly to these engines but I was not concerned with this. I was going to fabricate the bell housing so that this would mate to my AX-15 because it is strong enough. A salvage yard in Detroit called Mitch's had the transmissions & transfer cases used with the LD28 but I never pursued these. I doubt their is much inteterest in these drivetrain parts so they may still have them. I think a compact Nissan pickup truck used to have these same drivetrain parts but I cannot remember what it was called.
After posting this ad and "bumping" it I remembered I do have a Nissan 810 service manual. I should also have the electronics for the glow plug heating. However, I am uncertain where these items are but they must be here.
Rick
RAVC1 is offline
Old May 11th, 2009, 10:40 PM   #6
jeepers48
jeepers48's Avatar
Sorry, i thought it was the same Diesel used in a CJ10a tug. I looked up the motor, what im looking for is a Nissan sd33 diesel with a 727 tranny. Good luck on the sale.
Page generated in 0.18557 seconds with 41 queries
