EB axle swapped for a full size axle? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 26th, 2009, 12:55 PM   #1
SageJp
SageJp's Avatar
Default EB axle swapped for a full size axle?
Will a '79 ford f150 or bronco axle bolt up to a early bronco suspension with little to no mods?
Anyone know some good suspension tricks for the EB suspension?
SageJp is offline   Reply With Quote
Old April 26th, 2009, 12:58 PM   #2
Broncoholic
Guest
Posts: n/a
Yep have to get the 78 - 79 rad arms or move your perches in board.
Same on the rear 9" 78 - 79 is the best swap for this.
Best be is to get JDuffs or Cage arm's Long arm kits
Old April 26th, 2009, 12:59 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
You will have to move the coil buckets out away from the frame for a 79 front. If you get a earlier front you can cut off the radius arm wedges and move them in to match the EB front on the axle itself
Old April 26th, 2009, 01:12 PM   #4
Broncoholic
Guest
Posts: n/a
Cut your spring upper mounts to tilt out 11* and do the same with your lowers tilt toward the axle 12* it will center you axle & flex better. 2c
Old April 26th, 2009, 01:59 PM   #5
SageJp
SageJp's Avatar
Thanks, I have a YJ with a EB suspension and front axle on it and I think the front axle is bent. Plus the front suspension doesn't flex very much. I went to the junk yard and measured a 79 broncos radius arm mounts on the axle and they were only a inch wider.
Thanks for your help.
Old April 26th, 2009, 04:18 PM   #6
firehawk
Live Action!
firehawk's Avatar
I thought it could just bolt in, the radius arms just are slightly angled.
I have full width axles I plan on putting in my EB this year.
Old April 29th, 2009, 09:38 AM   #7
Broncoholic
Guest
Posts: n/a
The 78 -79 arms are bent a little bit in board.
If you go that route your springs will bow outward.
Best to angle the mounts a little. Help center it.
Page generated in 0.21053 seconds with 44 queries
