302 shaking??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2009, 05:01 PM   #1
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
Default 302 shaking???
I got my engine in on my b2 and I had a hard time getting it start. After I got it started it shakes really bad like its out of time or out of balance. It should be balanced right. It has a 85 or 86 cougar engine with the balancer that came on it and a 89 flywheel. So it should be 50 oz. imbalance. I've pulled the distributor about 20 times in two days checking and double checking that it I have in right. It doesn't backfire or pop at all. It will hardly run long enough with the vacuum advance unhooked and plugged to check the timing, but it will run with it hooked up and its reading 10* at idle.
I can't advance it anymore than that because it up against the thermostat housing. I need some more ideas.
fordlovinfarmer is offline   Reply With Quote
Old June 16th, 2009, 05:40 PM   #2
88mudder
In the band!
off a tooth
Old June 16th, 2009, 07:43 PM   #3
FARMERDAVE
Send a message via AIM to FARMERDAVE
The wrong balancer or the wrong flywheel! A tooth off on the cam wouldn't make it shake!
FARMERDAVE is offline   Reply With Quote
Old June 16th, 2009, 07:55 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
firing order off? that will make it shake. that and fuel fouled plugs.
Yetti
Old June 16th, 2009, 08:03 PM   #5
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
2 things:
Mine shook really bad, but it had a miss when reved. Here is the video I took with my dad starting it. when the camera shakes it was because I was leaning up against the hood brace.
http://www.youtube.com/watch?v=pBqf-4-pZaw
The issue ended up being I had some wires opposite on the distributor of what they should have been. Does it sound similar?
*Edit: Yetti suggested the same issue while I was making my post Ha!
2:
The distributor issue, I ended up setting it up one prong over. give the distributor a twist away from the housing untill all the cap prongs are about in line where they used to be, and move all the wires back over the other way one prong at a time. (I think thats how I did it) I have all the room in the world to adjust things now.
** edit edit: I also remembered it being a real biotch to get running, and yes, it died alot and very easily.
I'd re-check your fireing order.
Old June 17th, 2009, 08:17 AM   #6
trailrail302
Im going FAST!!!
trailrail302's Avatar
may have the firing order off or you could have the wires crossed somewhere even if you have one wire switched it will start and run but shake bad and run like crap...Re check firing order and your wires.
trailrail302 is offline   Reply With Quote
Old June 17th, 2009, 10:58 AM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
check the firing order for a 86 couger, firing order changed between applications
Old June 19th, 2009, 11:50 PM   #8
shredder70
Chillin with the top off.
shredder70's Avatar
change it to a 351 firing order and try that. Some of the 302 engines had 351 cams and 4 of the cylinders are different firing order.
shredder70 is offline   Reply With Quote
Old June 20th, 2009, 11:37 PM   #9
Never_Evil
A lot of people are pointing to the firing order/wire routing and I would agree. I would also check the wires and make sure they aren't arcing out.
The 1986 cougar had a 1-3-7-2-6-5-4-8 firing order (351w/302 HO firing order)
Most carbed 302's are 1-5-4-2-6-3-7-8 as a standard 302.
Please update us if its corrected or still a problem
Also check for vacuum leaks, fuel supply, reset your distributor to factory position and start fresh.
Old June 21st, 2009, 12:42 PM   #10
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
carb or fuel injection?
Old June 21st, 2009, 02:10 PM   #11
Broncoholic
Guest
Posts: n/a
Best guess ...
Old June 25th, 2009, 06:09 PM   #12
Never_Evil
Along with the firing order, make sure its going in the correct rotation.
Old July 1st, 2009, 06:25 PM   #13
shredder70
shredder70's Avatar
any updates?
Page generated in 0.25502 seconds with 62 queries
