Ford Ranger ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2009, 09:51 AM   #1
fsumotorhead
N8KVB
fsumotorhead's Avatar
Default Ford Ranger ???
I am swapping in a manual t-case into my '96 5spd Explorer.
I need to know where EXACTLY to cut the hole in the floor so i don't butcher it.
Can someone post a pic of the inside showing both stock shifter locations?
Also did ford use a double shifter boot, or two single ones side by side?
Thanks
Old April 23rd, 2009, 11:15 AM   #2
the 91-94s used a double boot.....I can't say i've ever seen a manual shift 2nd gen explorer....... post some pics when your done.
Old April 23rd, 2009, 11:26 AM   #3
fsumotorhead
N8KVB
I have a manual trans, but 2nd gens didn't have manual t-cases
Here are a couple pics i found on google, but they are both different...sigh
Is it more like A or B?
ID:	42044   Click image for larger version
Old April 23rd, 2009, 11:32 AM   #4
first gen explorers and 2nd gen rangers look like A
did you search on www.explorerforum.com
Old April 23rd, 2009, 11:39 AM   #5
fsumotorhead
N8KVB
I'm thinking B was from a 1st gen ranger??
...and yes, but nobody seems to have manual trans's there
Old April 23rd, 2009, 11:58 AM   #6
B is to new for a 1st gen ranger, i don't think first gen rangers had that style trans shifter boot. Taht was more a m5ord shifter boot and don't think those were released until 89 (2nd gen).
Is the 4r553 or 5r55e longer then an a4ld? If so then I would assume B would be what you want.
Didn't notice before, but i Think pic A is "4x4Junkie" 2nd gen B2 (on another site)....it has the extra handle for the 1350/54 doubler in the pic.
Old April 23rd, 2009, 12:10 PM   #7
fsumotorhead
N8KVB
I have a M50D R1, which has a similar boot to both pics...shit!
Old April 23rd, 2009, 12:40 PM   #8
and a 1354 right from a 91-94 ranger or explorer? and did the shifter assm. come from the same trans?
Old April 23rd, 2009, 12:50 PM   #9
fsumotorhead
N8KVB
i'm assuming so, it all lines up according to my eyes. I'll let you know tonight when i start cutting!
Old April 23rd, 2009, 01:36 PM   #10
I have the m5ord and 1354 in my truck....I THINK the shifter set-up is like A. Just install the tcase to the trans and see where the shifter sits and measure. Then install the trans into the truck. When you lift the trans into place the shifter stub will hit the floor giving you the mark where to cut for that then just take your previous measurement of where the shifter was in realation to that and cut the floor accordingly.
Old April 23rd, 2009, 08:14 PM   #11
fsumotorhead
N8KVB
well i didn't have to cut the floor, just the cover plate for the trans.
It's more like B but kind of in between, i need to find the right boots though as the two bezels interfere with each other. i'm usually crunched for time in the garage so i didn't pull up the carpet first, i just made small cuts at a time :)
you can see they don't quite fit next to each other, and the 4x4 shifter shaft is against the 5spd bezel
Old April 23rd, 2009, 08:15 PM   #12
fsumotorhead
N8KVB
Thanks for the input
Old April 23rd, 2009, 08:24 PM   #13
looks like it was meant to be there
Page generated in 0.75148 seconds with 63 queries
