89 3.slo 4skinner won't start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 22nd, 2009, 09:26 PM   #1
BOGDOG
BOGDOG's Avatar
Default 89 3.slo 4skinner won't start
I finally got time to put this thing back together and now it won't start. I bought it about 3 years ago yhen was too busy to fix, It ran great but after sitting it won't start without starting fluid then it will not keep running. I put a couple gallons fresh fuel in it but no help. My FSM is for 85 4runners. I am thinking it is probably fuel related but not sure where to start. I thought i heard the fuel pump for a few seconds when I 1st tried to start it but not since then. Anybody got any ideas?
Old April 23rd, 2009, 06:03 AM   #2
Rattler
Home Sweet Homicide
Rattler's Avatar
I would check the dist. cap for corrosion first.
Old April 23rd, 2009, 12:30 PM   #3
BOGDOG
BOGDOG's Avatar
Default 4runner
Thanks I will check into that first.
ID:	42046   Click image for larger version
ID:	42047   Click image for larger version
Old April 28th, 2009, 12:27 PM   #4
BOGDOG
BOGDOG's Avatar
Checked distributor cap looks like new. Motor and Trans were supposedly replaced with factory units 10K miles ago so it should. No fuel from pump anybody know if a fuel pump from a 22RE is the same? I have a couple of those around but one of those is has been sitting longer than this one. Last time I needed one it was $100 @ Autozone with a lifetime warranty.
Old April 28th, 2009, 01:44 PM   #5
Rattler
Home Sweet Homicide
Rattler's Avatar
They might be the same pump. Out of curiosity, I went to car-part.com and it never asked me what size enigine for it.
Old April 29th, 2009, 12:31 PM   #6
BOGDOG
BOGDOG's Avatar
They asked a pimp boys but some of those places ask about stuff when I know it doesn't matter. $135 w/1 year warranty. I am going to check a couple more places.
Old June 3rd, 2009, 12:22 PM   #7
BOGDOG
BOGDOG's Avatar
I pulled pump annd could not get it to do anything. Installed new pump and can hear it running but no fuel seems to be getting to engine. Anybody got any ideas?
Old June 4th, 2009, 07:42 AM   #8
elripster
Not-So-Newbie
elripster's Avatar
Try this... http://personal.utulsa.edu/~nathan-b...fsm/index.html
If it starts with starting fluid, you probably have a plugged up cold start valve. It's the passenger side of the manifold. Pull it off and have someone try to start it with the coil wire disconnected. Look for a strong stream (sound like a prostate commercial...).
Two more culprits of bad idle are the air flow meter in the air filter box or the throttle position sensor. Both could be corroded or in the case of the AFM outright stuck shut.
Frank
elripster is offline   Reply With Quote
Old June 4th, 2009, 12:26 PM   #9
BOGDOG
BOGDOG's Avatar
It won't start or idle nothing coming out of line I removed I think it is Cold start valve.
Page generated in 0.18638 seconds with 51 queries
