House's Used Car Lot !!! Cars/trucks/pontoon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2009, 09:49 AM   #1
House
House's Avatar
Send a message via AIM to House Send a message via Yahoo to House
Default House's Used Car Lot !!! Cars/trucks/pontoon
Time to weed out my collection
1. 1977 Chevorlet 3500 2wd Dually, 355ci, turbo 400, 3.73 gears, runs and drives good, has a 8ft flatbed on it, cab is very rusty, front end is multi colored, good work truck
$1200.00
2. 1978 Ford 150 4x4 with rare 8ft step side bed.
I am the 3rd owner of the truck. It sat for 15 years before I got it when i was 16(now 27) at the time I had the body and paint, along with motor redone.
Truck has 70,800 Miles on it.
400m 2 barrel carb, 10k on over haul on motor, carb just rebuilt 2 weeks ago.
4 speed manual with center force dual friction clutch
9 inch rear with moser nodular case, aluminum pinon support, moser 31 spline axles, detroit locker, 3.55 gear
44 front with open diff, 3.55 gear, warn lock outs
4 inch rancho lift, rancho shocks, newer ford aluminum rims, 35 inch uniroyal mt's (2 30% 2 are slicks)
tube bumpers, front set up for winch
high idle switch in cab
set up for dual battery's but only has one battery in it.
rock proof steering system from http://bulletproofsteering.com/
Truck runs great, carb rebuilt in last 2 weeks, fuel pump in last 3 months. The bad is the breaks do not work, i think power booster is bad. as I added a master cylinder a year ago and didn't fix the issue of hard pedal.
I have a new door that needs paint that goes with the truck and orginal door that goes along with to have matching locks. had a brown door on it now due to the fact the window track came off and bent.
I am asking $1800 OBO
Pics http://www.facebook.com/album.php?ai...8&l=66e77c6caa
3. 1979 GMC Prostreet drag/show truck
1979 GMC Pro Street Drag Truck $$8000.00
+ 468 Cubic Inch Big Block Chevy
-Forged Crank and Rods
-Keith Black Forged Pistons
-10.5:1 Compression
-Ultradyne Hydralic Cam
-LS6 Heads
-Weind X-CELATOR intake
-Holley 750 Double Pumper Chokeless Race Carb
-Headman Full Tube Headers, 1 3/4"
-GM HEI Ignition
-Hypertech Coil
-Nitrous Express 50-300HP adjustable nitrous kit, with
purge, installed, never used
-Professionally built by Hedricks Precision Engines in
Champaign, IL
+ GM TURBO 400
-Built by Coan
-10 inch 3500 stall Coan Converter
-Hurst Quarter Stick Shifter
+ Chasis
-Factory Chassis, back-halved
-Competition Engineering Ladder Bars
-A.R.T. (Applied Racing Tech) Adjustable coilovers rear
-3 inch Belltech drop spindles
-Competition Engineering Wheelie Bar
-Narrowed Ford 9 inch
-Strange 33 Spline Spool
-Moser 33 Spline Axle Shafts
-Moser 4.30 Ring and Pinion
+ Interior
-Grant GT Steering Wheel
-Billet Dash Inlays
-Auto Meter Sport Comp Series Gauges:
-3 3/4" Tachometer
-Liquid filled Oil Pressure and Water Temp
-Autometer Pro-Shift Light
-Auto Meter Pro Controller
-New Black Carpet
-Black Bench Seat
-Sony 6x9 Speakers
-Dennon AM/FM Cassette
-Sliding rear window
-Tinted windows
+Body
-Harwood Cowl Induction Hood
-Tubbed Bed
-Herculined inner bed sides
-Rubber Bed Mat
-Shaved side mirrors
-Tube Grill
-Black Out Headlights
-Roll Pan
-Small dent on drivers front fender (see pics)
-Scratch on passenger side door
+Wheels and Tires
-15x7 Weld Pro Stars in front
-15x15 Weld Pro Stars Rear, drilled and tapped for screws
-31x16.5-15 Mickey Thompson Sportsman rear tires
-Comes with un mounted 33x16-15 Goodyear Drag Slicks and Tubes
Truck has less than 500 miles on it since built, well kept in climate
controlled storage unit. Ran very little, never raced, only shown at
local car shows. Lost interested in this truck for another project.
Insurance appraised this truck at $15,000 asking $8000.00
Pics can be seen at http://rides.webshots.com/album/281865560LhmkWu?start=0
4. 1997 Ford FSuperduty(450) Std Cab 12 ft flat bed, with gooseneck, 7.3 power stroke diesel, 300K Miles, runs good uses no oil!, Brand New from ford with 25 miles zf5 manual trans, LUK Clutch, 130cc Beans Diesel Injectors, Superchips programer, well maintained , oil changed every 3-4,000 miles
$5,000.00 obo pic http://photos-b.ak.fbcdn.net/photos-...05081_4236.jpg
5. 1987 Grand National T-tops Vin # 1g4gj1174hp464663
Rebuilt Indiana Title- I Was Told It Was Due To Stolen-recovered In The 90's, It Does Have An Aftermarket R.f. Fender (no Ant. Hole).
Runs And Drives Real Good, Shifts Real Good And Hard.
Has A Hot Wired Reds Fuel Pump,adj. Regulator, 36 Lb Injectors, Reds Chips 93 and 100, Reds Volt Booster, K&n Air Filter, 35 Lb A-pillar Mounted Boost Gauge,Larger after market front sway bar, ATR 4 Hole under radio console gauge, with volt and nitrous pressure(both not hooked up)(never bought the Nitrous kit) 4- Newer Tires On Decent Factory G.n. Wheels. Stock Downpipe, Stock Turbo. 2.5 inch single exhaust to a 3 inch stainless magnaflow. Drilled and Cross Slotted front rotors, Hawk Front Brake Pads, Koni Seal Front Brake Lines
Car has a Kenwood Flip out dvd player, Kennwood 6 1/2 rear, Infinity fronts, and 2 10 inch audio pipe subs, and a Visonik AMP, Sound system sounds really clean and low on bass.
Selling Miles Unknown. Shows almost 60k
Interior Is Very Clean, Has A 1" Tear In Bottom Of Drivers Seat, Needs head liner,Factory Radio-not Concert Sound, Power Windows , A/c, Cruise Tilt, No Power Trunk Release Although It Is Wired, and have trunk motor for it,
Car Was Just Painted 3 years ago and needs a lil TLC on top of roof and passenger sail panel
Comes with stock radio, stock visors, has a set of aftermarket from postons on it, stock turbo shield, New set of T Top seals, and a FMIC and plumbing
Price Is $9300.00 Need to sell soon.
Will get some better pictures of roof and sail panel this weekend.
Pictures located here http://viewmorepics.myspace.com/inde...=613740&page=1
6. 1998 Premier Horzion 24ft Pontoon with 2005 Yamaha 115 HP Four Stroke, and 2006 Tandem float on trailer, All IN good shape, a few rips in seats
$9500.00 http://viewmorepics.myspace.com/inde...albumId=778186
all prices are obo
House is offline   Reply With Quote
Old April 22nd, 2009, 10:31 PM   #2
House
House's Avatar
ttt
Page generated in 0.29666 seconds with 29 queries
