XJ Bumpstops Removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2009, 07:29 PM   #1
lotusexige
lotusexige's Avatar
Default XJ Bumpstops Removal
How do you remove the XJ bumpstops???
lotusexige is offline   Reply With Quote
Old April 18th, 2009, 07:46 PM   #2
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
the fronts just pull out, and the rear are bolted in.
jpr Jeremy is offline   Reply With Quote
Old April 18th, 2009, 07:51 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
Depends on the year, my 86 XJ unscrewed cup and all. You can pull the stop rubbers, it can just be fun getting them back in. If you're putting longer stops in, I take a big pair of channel locks and twist them out then lube the new ones and put them in with the aid of a prybar and blocks of wood.
Old April 18th, 2009, 08:50 PM   #4
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
or pull the cup and all and then vice in new ones.. easy
nate4d is offline   Reply With Quote
Old April 18th, 2009, 10:05 PM   #5
lotusexige
lotusexige's Avatar
thanks
Page generated in 0.28288 seconds with 38 queries
