Bar Pin Removal?????????????????????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 18th, 2009, 06:46 PM   #1
lotusexige
lotusexige's Avatar
Default Bar Pin Removal??????????????????????
Ive got an Xj and im putting on a rustys 3 inch lift. im changing the shocks and cant figure out how to remove the bar pin from the old shock bushing.
need help NOW!!!!!!!!!!!
lotusexige is offline   Reply With Quote
Old April 18th, 2009, 06:49 PM   #2
Freak
Wheelin the HD
Freak's Avatar
Is this on the old shock? had the same problem with my spring. The bushings swell and aside from burning them out you can sometimes pound them out.
Old April 18th, 2009, 06:52 PM   #3
ddeadserious
ddeadserious's Avatar
I've never had an issue just pounding them out. I've also used a clamp with a big, deep socket. I've also used a ball joint/u-joint press.
It's not exactly rocket science.
ddeadserious is offline   Reply With Quote
Old April 18th, 2009, 07:53 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Pounding doesn't always work for me, the bushing bounces back, but the rest works everytime. Even a vice will work.
Old April 18th, 2009, 08:48 PM   #5
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
except when we were putting ur dana 30 in ur xj and u pounded it out and it feel behind ur mess of a work bench to never be found again haha.
nate4d is offline   Reply With Quote
Old April 18th, 2009, 09:15 PM   #6
Put it in a big vise, with a socket pushing against the bushing on one jaw of the vise, and the bar pin against the other jaw.
Old April 18th, 2009, 10:05 PM   #7
lotusexige
lotusexige's Avatar
i got it out. used a MAUL and a socket.
HOW TO GET THEM IN THE NEW BUSHINGS?
Old April 19th, 2009, 07:39 AM   #8
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
you need to put them in the bushings before you press the bushings into the shock. a little grease helps out too.
jpr Jeremy is online now   Reply With Quote
Old April 19th, 2009, 11:45 AM   #9
ajmorell
You can get new bar-pins in after the bushings are in. Lube them up with grease good and pound them or press them in, I've done it several times.
Old April 19th, 2009, 03:46 PM   #10
Jt91bronco
Jt91bronco's Avatar
i just got theme in for you they, i cleaned them up with a wire wheel, lubed them with some 30 weight motor oil and pressed them in with a vice and some sockets.
Jt91bronco is offline   Reply With Quote
Page generated in 0.37515 seconds with 53 queries
