CJ-7 frame in pretty good shape - $50 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2005, 07:18 AM   #1
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Default CJ-7 frame in pretty good shape - $50
This CJ-7 frame was part of an abandoned project that has been sitting for a few years.
The good:
  • Frame has been cleaned up & painted, but will need touch-up
  • No rust holes in frame, including the underside by the rear main eye hangers. Frame is solid!
Needing attention:
  • Some of the body mount surfaces are a little thin around the holes.
  • Needs new rear crossmember; original crossmember was removed by the previous owner.
  • Previous owner cut a small slot in the front driver frame rail to repair the spinning shackle hanger nuts. You could plate over this, or leave it as-is. IMO, it's fine as-is.
I don't have pics yet, but can get some after the holiday weekend. This frame is still part of an assembled rolling chassis, including this NEW 2" suspension lift, and wide-track (3.31 open) axles from an '82 Scrambler. If you're interested in the frame/lift/axles, I'll give a discount price on the whole package.
$50 for the frame only. Located 15 minutes West of Grand Rapids.
Thanks,
Craig
1x1_Speed_Craig is offline
Old November 28th, 2005, 08:20 AM   #2
1x1_Speed_Craig
Simplify...
This would be a solid foundation for a Winter project...
Old November 30th, 2005, 10:29 AM   #3
1x1_Speed_Craig
Simplify...
Wow, I have seen some of the cobbled-together, holy (not in a religious context) frames under many of your CJs.
It'll probably be hitting eBay within the next 2-3 weeks. Catch me before then if you're interested.
Craig
Old December 7th, 2005, 02:45 PM   #4
1x1_Speed_Craig
Simplify...
*** Sold ***
Page generated in 0.41791 seconds with 35 queries
