is my tube strong enough - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2009, 11:38 PM   #1
RZG90
RZG90's Avatar
Default is my tube strong enough
i am building some radius arms for my 1985 k10 chevy and i was donated some 1-7/8"dia 3/16wall DOM tubing the tubes will only be about 27" long with no bends in them and the truck should weigh about 4500 pounds. should i still brace them or will they be ok?
RZG90 is offline   Reply With Quote
Old April 18th, 2009, 08:48 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
that size sounds fine. are you gonna jump the truck? either way roll cages are made out of that size material and hold up pretty good.
Old April 18th, 2009, 09:41 PM   #3
RZG90
RZG90's Avatar
no i dont plan on jumping it but accidents could happen but i just know that there is alot of force on those tubes and dont want anything to give way at 50 mph plus
Old April 19th, 2009, 01:07 AM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I would not use tube with that thin of a wall.
JcrOffroad
Zoom Zoom!
Old April 19th, 2009, 02:14 AM   #5
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Roll cages are a whole different animal with different requirements. 3/16 is WAY too small for links on a lightweight buggy, much less an 85 K10!!
*Personally* I wouldn't consider anything less than 3/8ths for lowers... (and I wouldn't even go that thin)
Nuzzy is offline   Reply With Quote
Old April 19th, 2009, 10:52 AM   #6
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Depends on the wheeling and on the weight of the truck. My old CJ had 1.75 x .180 DOM links way back then and never bent them...Did the Badlands , Paragon, trail riding, wheel stands (yes wheel stands).
Old April 19th, 2009, 11:12 AM   #7
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
mine are 1/4 in. dom and yes even on a samurai you can bend them
samurai2240 is offline   Reply With Quote
Old April 19th, 2009, 11:18 AM   #8
Yeah, but that was before the age of enlightenment. These days everyone nees to go overkill because they read some guy on pirate bent his links...
I wouldn't see any issue at all with that size, EXCEPT if your wheeling has you crashing the links down onto rocks/logs/etc.
That isn't too long of a link length, I think it'd be fine. For example, its not uncommon for people to have long lowers around 40-45" long. A 27" long 1.875x0.188" link is stronger, in bending moment, than a 44" long 2.00x0.313" link. (though not as dent resistant).
Old April 19th, 2009, 11:19 AM   #9
Who uses 3/16" wall for roll cages?
Old April 19th, 2009, 11:26 AM   #10
1badzuk
1badzuk's Avatar
jebus has spoken now use the tube
1badzuk is offline   Reply With Quote
Old April 19th, 2009, 12:25 PM   #11
Nuzzy
Nuzzy's Avatar
What other kind of wheeling is there...?
But do whatever link size floats your boat. I've seen too many friends waste money on thin links before finally going big to ever make that same mistake myself
Old April 19th, 2009, 12:29 PM   #12
Nuzzy
Nuzzy's Avatar
Ah fukc it. They're only radius arms and it's prolly only going in sand and mud. Just run what ya got and fix later if it's a problem.
Old April 19th, 2009, 12:30 PM   #13
1badzuk
1badzuk's Avatar
well seeing how the tube was free for him it probobly wouldent break the bank to purchase some tube to sleeve the free 3/16 wall stuff with creating some really srtong heavy wall (or solid if you want) links
Old April 19th, 2009, 12:41 PM   #14
Baxter
If it's for the truck in your Avitar go for it.By the looks of things you don't put that in the rocks and if you do you wheel for minimal body damage.
Baxter is offline   Reply With Quote
Old April 20th, 2009, 07:20 AM   #15
RZG90
RZG90's Avatar
no i dont do any mud or rocks or trees or anything with it i pretty much only drive it around town on weekends and run silver lake. i know that a jeep weighs a lot less but a friend of mine runs a cj7 with 1 1/8" X 1/8" thick DOM in the dunes and on street and hasnt had a problem with it
Old April 20th, 2009, 07:31 AM   #16
junk90xj
ALLPRO AUTO
junk90xj's Avatar
i wouldnt personally use tube that thin but for your application its more than likely fine.
http://www.apalansing.com/
Page generated in 0.39746 seconds with 71 queries
