Square Tube ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2009, 11:25 AM   #1
fsumotorhead
N8KVB
fsumotorhead's Avatar
Default Square Tube ?
What size square tube is used for reciever hitches?
is it 2.5"x 0.25" wall?
Old April 17th, 2009, 02:36 PM   #2
bmx0964
bmx0964's Avatar
i believe its 2.5"x.125" wall
I might be wrong though
bmx0964 is offline   Reply With Quote
Old April 17th, 2009, 03:47 PM   #3
You use.... receiver tube!!
Seriously, there is special receiver tube that doesn't have a weld seam and has better square-ness in the corners. But its like $20-$30 a foot. Get it from a good trailer shop.
But if you want to butch it, then use 2.5 x 0.250" wall.
Old April 19th, 2009, 01:32 AM   #4
Yota Bill
x2
the basic stock sucks, because you will need to use a die grinder to clean out the inside of the tubing around the corners, and the weld seam, or you wont even be able to get a hitch into it, let alone back out of it...
Old April 19th, 2009, 02:03 AM   #5
Ebs
I have a section of tube if needed, never used for some bumpers I was building, PM if interested.
Old April 19th, 2009, 11:34 AM   #6
fsumotorhead
N8KVB
good to know
thanks
Old April 20th, 2009, 09:36 PM   #7
dingle dave
PARTS SLINGER
dingle dave's Avatar
i bought my reciever tube at harbor freight for $12. Cut it to length and welded it in. Looks sweet!
dingle dave is offline   Reply With Quote
Old April 20th, 2009, 10:12 PM   #8
Arr-pea
Acceleration Junkie
Arr-pea's Avatar
It can be purchased thru anyone that sells Buyers Products, Northern Hydraulics carries it. I buy it local here from a truck fabricator.
Buy a 3 ft lenght and cut it up what you need. 3 inch square works for the end ring.
Arr-pea is offline   Reply With Quote
Page generated in 0.20042 seconds with 47 queries
