Fuel sending unit testing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2009, 09:39 PM   #1
88mudder
In the band!
Default Fuel sending unit testing
Is there a way to test a fuel tank sending unit with it out of the tank? I have a feeling mine is still good, but wasnt working becuase the terminals are rusting. Truck is a 84 Ranger and it has 2 metal prongs coming out the top where a connector goes over top. Thanks for any help.
Old April 16th, 2009, 10:03 PM   #2
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
ohm meter.
GNJEEPN is offline   Reply With Quote
Old April 17th, 2009, 01:34 PM   #3
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
if the gauge is known to work, connect it back to the truck and move it by hand and see if the gauge moves.
Old April 17th, 2009, 09:48 PM   #4
88mudder
In the band!
The terminals were so rusted out i tried cleaning them with a brush but the prongs just busted off. Can i just connect the main power wire to the power wire on the sender and ground the black wire? Like a manual hookup not using the connector.
Old April 17th, 2009, 09:51 PM   #5
Bishop
Bishop's Avatar
most cars have a buffer. meaning that the gauge doesn't react as fast as the sender does. so it may a peer to be bad when it really isn't. the best way to do it is with an ohm meter out of the tank.
Page generated in 0.14446 seconds with 38 queries
