Diff cover mod - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 16th, 2009, 12:11 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default Diff cover mod
I was looking at getting new diff covers mor for the drain holes than the protection. Someone suggested welding in my own. I like this idea as it would be a lot cheaper. The propblem i can't weld. Where would I get the parts and who could do it?
Silver Bullet is offline   Reply With Quote
Old April 16th, 2009, 01:30 PM   #2
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Drain Holes? You mean like to drain diff fluid? If that's what you're doing then get a Ruff stuff one and countersink a flat head bolt into the front of it. That way you should be able to drain it and not snap off a head when you hit a rock.
ckupq is offline   Reply With Quote
Old April 16th, 2009, 01:33 PM   #3
Yota Bill
it seems i have seen a product before that was meant for adding a drain plug to a trans pan, but would also work in this case...IIRC, you just drilled a hole, and then installed the adaptor part, which was o-ring sealed and locked in place, and then the drain plug threaded into that, so no welding required...
you'll have to do some searching though, I dont really remember anything about it, but seems i saw it on one of the car/truck tv shows a few years ago or something...
Old April 16th, 2009, 02:26 PM   #4
xjmichigan
xjmichigan's Avatar
Are you lazy or what, just pull the cover.
Old April 16th, 2009, 03:17 PM   #5
Silver Bullet
yes, yes i am.
Old April 16th, 2009, 04:29 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
so you can clean off all the old RTV/gasket material from the diff ANd cover.. then reapply a fresh bead not to mention zipping off the 10-14 bolts and keeping the fluid from dumping all over while prying it loose. only cause you got water in your fluid.. yea i think pulling one bolt and letting drain then resinstalling that bolt makes a lot more sense..
PS i just drilled and tapped a 3/8's hole in my ruffstuff covers..
Old April 16th, 2009, 05:36 PM   #7
booblinker
Sore and Tired 24/7
booblinker's Avatar
Dorman part #090-048, 090-085, 65128, or 65241. I think the difference is size, but dont think it will work good for rear end dope, since the hole is small.
Old April 17th, 2009, 06:47 AM   #8
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I thought most parts stores carried these in a "kit"?? Might have to look at the "kit" for a tranny pan?
RIP FULLSIZE4LIFE
Old April 17th, 2009, 01:09 PM   #9
xjmichigan
xjmichigan's Avatar
And you cannot get all mud/water out by pulling a drain plug.
Raise your axle vents, and run fresh seals.
Old April 17th, 2009, 02:38 PM   #10
Silver Bullet
I do need new seals but do not know wtf I am doing with the rear axle.
Old April 17th, 2009, 05:52 PM   #11
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
pay me to do it
Old April 17th, 2009, 05:53 PM   #12
Pokerob
hug life
Pokerob's Avatar
Originally Posted by unclebeaner View Post
pay me to do it
x2
do it....
heard UB can lay a preety hot bead
Old April 17th, 2009, 08:33 PM   #13
Silver Bullet
pay me to do it
Ill work on your house while you wrench.
Old April 17th, 2009, 11:04 PM   #14
unclebeaner
you gonna fix me some drywall cracks or hang doors ? im sure we can work something out
Old April 18th, 2009, 01:46 PM   #15
Silver Bullet
fawk it both
Old April 19th, 2009, 05:38 PM   #16
unclebeaner
sold item get ahold of me. you gots the number and email and address
Page generated in 0.40024 seconds with 71 queries
