88 honda cr250 hard start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2009, 07:37 PM   #1
raminator04
Default 88 honda cr250 hard start
i have an 88 cr250 it dosent want to start unless i spray starting fluid or carb clean in it. the choke seems to be working fine and it usually starts first kick after its been running and its warm.any help would appreciated
raminator04 is offline   Reply With Quote
Old April 15th, 2009, 07:41 PM   #2
babyjp95
average guy
babyjp95's Avatar
check the fuel line i had a similar problem with a snow blower and the line was clogged
babyjp95 is offline   Reply With Quote
Old April 15th, 2009, 07:43 PM   #3
raminator04
it seems to flow fine
Old April 15th, 2009, 09:17 PM   #4
Nvrenuf
Nvrenuf's Avatar
Check compression it will start hard if it's getting low.
Is it any better with new gas?
Old April 15th, 2009, 09:31 PM   #5
raminator04
compression was what i was thinking, i just got to remember to bring a guage home. iam unsure on on the psi spec ive been getting mixed answers. iam going to just guess it should be above 150
Old April 15th, 2009, 09:48 PM   #6
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
Buy a new piston and rings.
Spence1986 is offline   Reply With Quote
Old April 15th, 2009, 10:55 PM   #7
Cartman
Can't lose with 42s
Cartman's Avatar
Clean the carb, pay close attention to the needle & seat and the pilot jet.
I doubt its compression, normally if they are low they won't idle and they will start fine cold but won't start after they have been warmed up
Cartman is offline   Reply With Quote
Old April 19th, 2009, 02:55 PM   #8
xNewhaven11
Four Wheel Drive
xNewhaven11's Avatar
Send a message via AIM to xNewhaven11 Send a message via MSN to xNewhaven11
x2
xNewhaven11 is offline   Reply With Quote
Old May 5th, 2009, 07:54 PM   #9
Jeepaholc92
Jeepaholc92's Avatar
my 87 xr250 wouldn't start but with a new de-compresion cable, plug, and tank of premium she fired right up....it's an idea
Jeepaholc92 is offline   Reply With Quote
Old October 9th, 2009, 07:04 AM   #10
crazygrady127
crazygrady127's Avatar
It could be as simple as a plug, clogged air filter, or a simply adjustment on the carb, You may need to rebuild the carb / but start by taking it off and cleaning everything and all the jets / you may even need new jets ? How old is the gas in it ? Have you ever let the gas sit in it for long time ? Good news for you is that a whole carb rebuild kit is pretty cheap / Ebay !! Im asuming this is a 4 wheeler first year after the cr 250 r or it could be just that ? I forgot exactly when they stopped making the cr 250 r / anyway when you take the carb off check the reeds inside the boot on the head , those wear out too but once again there pretty cheap ! you may have to go to a dealer for those , if you just flip them over, sometimes you can get a couple more years out of them ? If you dont have a manual I suggest you get one ? Once again ebay ? Good luck !!!!!! When it comes to carbs you need a manual !
crazygrady127 is offline   Reply With Quote
Old October 9th, 2009, 07:21 AM   #11
diesels77
Hold on
diesels77's Avatar
Check your reeds.
diesels77 is offline   Reply With Quote
Old October 9th, 2009, 05:29 PM   #12
IFS SUCKS
I like trees
IFS SUCKS's Avatar
http://www.bikebandit.com/
IFS SUCKS is offline   Reply With Quote
Old October 9th, 2009, 06:02 PM   #13
jeepguy74
jeepguy74's Avatar
cr 250r is a motorcycle..i think you are thinking about a trx250 quad or atc 250r 3 wheeler....
raminator as stated it would be best to go through the carb...
compression should be above 120.....
start simple change the plug and make sure the carb is clean as hell
Old October 19th, 2009, 09:29 PM   #14
04silverado
well if the piston and rings are bad you will be able to tell cause i got a 86 lt250r and the compression was low and i could tell just by trying to start it but my reeds were bad to and it coulda been from that but it would only start with starting fluid and when it was warm it would start fine without it .i know for my quad it was a little over 200 for a 80 over piston with rings reeds and gasket kit from c&c sports in brighton
04silverado is offline   Reply With Quote
Page generated in 0.34052 seconds with 65 queries
