Making Big Coil Spring Spacers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2009, 11:31 AM   #1
bmx0964
bmx0964's Avatar
Default Making Big Coil Spring Spacers
I have 2 ideas for this and would like some input on them. I need to achieve around 4"-6" of lift.
Idea 1:
Make a custom block (have a large cnc machine at work) that will fit above the axle and below the coil spring seat. Then weld the block to the axle and the spring seat to the block. I would also make some kind of machined clamp for the top and bottom of the spring to hold it in. The thing i'm worrying about is axle wrap. What do you guys think?
Idea 2:
Make a custom block that will go on the top of the coil spring and bolt into the original top spring mount. I would also make a custom machined clamp for the top and bottom to hold the spring in. Which is better?
bmx0964 is offline   Reply With Quote
Old April 15th, 2009, 11:35 AM   #2
xj4life
xj4life's Avatar
Old April 15th, 2009, 11:38 AM   #3
blownexploder94
Todd
blownexploder94's Avatar
buying a lift is better
Old April 15th, 2009, 11:39 AM   #4
LILL ZJ
LILL ZJ's Avatar
Is this going to see street use? Nevermind it doesnt matter you dont want to do that anyways
LILL ZJ is offline   Reply With Quote
Old April 15th, 2009, 11:42 AM   #5
bmx0964
bmx0964's Avatar
no its a bogger. the truck is a piece so i dont wanna put $250 into new coil springs and I cant find any used ones. plus i can do this for free
Old April 15th, 2009, 11:48 AM   #6
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
If it's a linked suspension how will you get axle wrap?
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old April 15th, 2009, 11:48 AM   #7
HammerheadCVS Inc
If it is the f150 style with radius arms, I have made blocks before for lift but not at the bucket end but at the diff. This way you can build tappered blocks to correct pinion angle. 3" is the largest block I have used. Be careful not to rotate the diff too far as this affects you caster alignment and will make your truck skittish like a SHOPPING CART.
HammerheadCVS Inc is offline   Reply With Quote
Old April 15th, 2009, 11:53 AM   #8
bmx0964
bmx0964's Avatar
ya its a 1978 F150 with a 460. Probably should have put that in the beginning lol.
But as it sits right now (and I bought this way) it has 2 coil springs that are spun together for the lift but that seems realllllly dangerous so I want to fix that. For the shock mounts there was just some fabbed up steel to lower the top mounting location to create lift. But I already got new shocks (the right size). So I dont think that I would have to do anything with the pinion angle because its fine now.
As far as axle wrap goes I was thinking because you can get it using too big of blocks on leafs.
Old April 16th, 2009, 02:54 PM   #9
HammerheadCVS Inc
Yay fix that! Are the radius arms dropped appropriately?
Old April 16th, 2009, 06:33 PM   #10
Idea #2 is a lot better than idea #1.
I would re-work the front buckets. They should unbolt from the frame, if I remember correctly.... remove them, add in a sturdy spacer, then attach the buckets to the spacer. A large piece of 3/16 or 1/4 wall rectangular tubing should do the trick.
Old April 16th, 2009, 08:11 PM   #11
bmx0964
bmx0964's Avatar
@Hagger:
Good idea! That made me think of another idea that might work. What if I unbolted the front buckets and flipped them over then bolted them back on upside down?
Old April 17th, 2009, 06:06 AM   #12
mudbillyredneck
mudbillyredneck's Avatar
Originally Posted by bmx0964 View Post
@Hagger:
That would be awsome......do it and take pics
mudbillyredneck is offline   Reply With Quote
Old April 17th, 2009, 10:07 AM   #13
bmx0964
bmx0964's Avatar
haha well my plans for this weekend are to either flip them and remount in the stock spots or weld some rectangular tubing to the frame and remount the top mounts to that.
I will take pics either way and post them tho.
Old April 17th, 2009, 10:24 AM   #14
fsumotorhead
N8KVB
fsumotorhead's Avatar
@Hagger:
if you unbolt them, or cut the rivits, move them down, there are four holes, move the top bolt to the bottom and drill a new set of holes.
Nets about 3" of lift and isn't stupid
Old April 17th, 2009, 01:35 PM   #15
bmx0964
bmx0964's Avatar
thanks but i need closer to 6. there is 6 on there now but i think i can make do as low as 4 but i dont want to go any lower
Page generated in 0.51154 seconds with 68 queries
