FAWKING FORD SUPER DUTY!!! Front end grinding noice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2009, 06:35 PM   #1
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Default FAWKING FORD SUPER DUTY!!! Front end grinding noice
My truck: 2002 F-250 Diesel, 4x4, Auto, no lift, 81k miles...basically stock
Heres the run down. Under normal driving conditions, driving straight, cornering... you hear what sounds like a physical grinding noise and feel a vibration like you were driving on rumble strips. This all "feels" like it is comming from the front drivers side, like in the front axle or under the drivers floor.
I have just replaced the unit bearing hub, ball joints, caliper, brake pads, rotor, lockout hubs... and the problem is still there.
I have searched online for hours and found many with the same problem but no useful answers.
I was just curious if any one has experienced a similar problem or any advice on what to check out.
Basic example of a posted online question:
Ford F250 Super Duty 4x4 - Year 2003 - 207,000 miles. I get INTERMITTENT vibration, grinding and rubbing noises seemingly from the left front of the truck. The noises and vibrations come and go and seem to be triggered on and off by hitting bumps in the road. Although not always. Volume of noise and vibration varies from barely noticeable to as loud as running over rumble strips at highway speeds. After a severe episode it seems to go away for a while. I had a Ford Dealer do a front end inspection and safety check and they could not find anything. Now at my regular service providers location, and after a full day and test drives by different people they also are stumped. I am concerned about safety when driving at highway speeds, or also doing more damage by driving the vehicle.
I'm the man in White.
Old April 14th, 2009, 06:43 PM   #2
dodgeboy
redneck truck club
dodgeboy's Avatar
i had a problem like this and it was the front driveshaft! the double u-joint end was coming apart. took it out and drove it around the noise wasnt there. had the shaft rebuilt and no problems anymore
dodgeboy is offline   Reply With Quote
Old April 14th, 2009, 06:46 PM   #3
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
but if the hubs are unlocked the front driveshaft shouldnt be spinning to make the vibration. so unless you in 4wd or the hubs are locked in you shoudlt get a vibe frm the CV going bad
MJ_Silver_1988 is offline   Reply With Quote
Old April 14th, 2009, 06:49 PM   #4
joe_jeep
welfare wheeler
joe_jeep's Avatar
mine has a vibration, and a kind of squeal or even squeak when i turn. mine is bad ball joints. the ball joints are famous for going bad. yours could be that too? or even wheel bearings. both are common super duty failures. i found no name ball joints on escam super cheap!
good luck!
the shift on the fly front ends spin all the time, im pretty sure. part time fronts will stop spinning when unlocked, in case its a front driveshaft.
Old April 14th, 2009, 06:53 PM   #5
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
did you do all the stuff you said on both sides. sound could transfer or bad tires
samurai2240 is offline   Reply With Quote
Old April 14th, 2009, 07:44 PM   #6
shifty_85
2 low for fat hoes
shifty_85's Avatar
Send a message via AIM to shifty_85 Send a message via MSN to shifty_85
my buddy had an 02 f-250 same prob over and over its the wheel bearings every time it was the ball joints once. both are common on the super dutys
shifty_85 is offline   Reply With Quote
Old April 14th, 2009, 07:45 PM   #7
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
i also think the vibes could be coming from the tires.
Old April 14th, 2009, 07:59 PM   #8
shifty_85
2 low for fat hoes
shifty_85's Avatar
out of balance tires might do it too
Old April 14th, 2009, 08:01 PM   #9
jeepxj2007
Send a message via AIM to jeepxj2007
ours did the same thing twice now, both times the ujoints were either seized up or worn out in the axle shaft
jeepxj2007 is offline   Reply With Quote
Old April 14th, 2009, 08:11 PM   #10
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
an out of balance tire will not cause the problems he is having.
take the front drive shaft out, drive it and see what happens.
Old April 14th, 2009, 10:11 PM   #11
frdboy
frdboy's Avatar
Pull the front driveshaft and check all the joints and make sure both front hubs are disengaging. One could be still engaged at times spinning the front shaft.
Did you replace both front hub bearings? Does the noise change at all if you turn slightly while gong down the road?
Old April 14th, 2009, 10:56 PM   #12
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
I agree with axle ujoints. Jack up the front end turn the tires to one side, lock in the hubs and spin the tires, one at a time, if you get any binding replace joints.
Woodyjiw is offline   Reply With Quote
Old April 14th, 2009, 11:01 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
you're fucked.. just tell your dad to take it in and get it fixed
Old April 14th, 2009, 11:04 PM   #14
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
X2 Same year as the post.
Also, make sure if its the diesel that you are not running D rated tires. I broke bands in three of my BFG TAKO not realizing they were under rated.
Thank You Bell Tire
Old April 15th, 2009, 12:00 AM   #15
blownexploder94
Todd
blownexploder94's Avatar
seems weird it goes away, but had a friend have this happen sounded like right front and put all new front end parts in it both sides, still there, ended up being pinion bearing in the rear axle i guess it would echo, it had 3 different shops stumped cuz it sounded like it was from the front, not saying at all this is your problem just something similar
Old April 15th, 2009, 10:48 AM   #16
shifty_85
2 low for fat hoes
shifty_85's Avatar
yup take it to the dealer ur pretty much fucked when ur truck makes any noise acording to this guy
sum people know how to fix there stuff big guy
Old April 16th, 2009, 11:04 AM   #17
Broncoholic
Guest
Posts: n/a
Get some new Michies & remove drive shaft. My front end is fukced too on my 99 SD.
Old April 16th, 2009, 03:00 PM   #18
Skooter_Built
fixed the grind noise, it was the unitbearing on the passenger side. Good as new now.
Old April 21st, 2009, 12:26 PM   #19
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Would the noise/vibration stop if you put it in 4wd? If so, it's probably the bearing at the back of the unit bearing where the axle shaft goes through. They tend to wear out and cause these weird problems, plus they're a lot cheaper than buying a complete unit bearing.
Old April 22nd, 2009, 01:55 PM   #20
Skooter_Built
winner winner chicken dinner for you sir. I plan on pulling the small bearing on the back side and have a new 1 installed. It will make for a good spare if need be.
Page generated in 0.45453 seconds with 83 queries
