identifying c4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 14th, 2009, 02:45 PM   #1
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
Default identifying c4
whats the easiest way to identify a c4 trans. my friend has 3 trucks behind his house, says they all have c4s, but just looking at the trans pan, theirs 3 different tranys? so how do i tell which one is a c4
lososjoyride00 is offline   Reply With Quote
Old April 14th, 2009, 02:56 PM   #2
11 pan bolts and the pan is square except for a little bump in the corner.
Old April 14th, 2009, 02:58 PM   #3
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
if its a full size early 80ish it will be a big bell c4 and the dipstick will be bolted to the pan, if its a medium bell then it was from a car and the dipstick will be in the case, now the rarest of all c4's came in the 75-78 mustang II, it was a small bellhousing unit and used a tiny torque converter.
Old April 14th, 2009, 07:36 PM   #4
Tacker
Tacker's Avatar
Like CTB2 said on the pan. C4's also have removable bellhousing's. A C5 trans looks the same as a C4 other than the pan has a deep sump in the middle of the pan. Hope this helps.
Old April 14th, 2009, 07:52 PM   #5
lososjoyride00
thanx guys. i got a c5 off CTB2 and im lookin for a c4 to stuff in the ex so i can finally get a good drivetrain.
Old April 14th, 2009, 07:59 PM   #6
Tacker
Tacker's Avatar
Get a c4 bellhousing, converter, and valvebody for your c5 and you will be set, that is what I have in my Ranger.
Old April 14th, 2009, 08:39 PM   #7
I think he wants a c5 bellhousing and c4 everything else
Old April 14th, 2009, 09:03 PM   #8
luvitmyjeep
broken
luvitmyjeep's Avatar
inbeforitexplodescomment.
and subscribed for info
luvitmyjeep is offline   Reply With Quote
Old April 14th, 2009, 09:04 PM   #9
he has a c5 bell housing..hes looking for a c4 body to bolt the c5 bell housing to
Old April 14th, 2009, 09:06 PM   #10
Tacker
Tacker's Avatar
I see .
Old April 14th, 2009, 09:14 PM   #11
lososjoyride00
i would just rebuild the c5, but i want something to put a good transfer behind. 300,something strong, so i can move my weak link somewhere else.
Old April 14th, 2009, 09:19 PM   #12
1354 isn't weak fwiw
Old April 16th, 2009, 08:50 PM   #13
lososjoyride00
i had thought about using the c5, and doin a doubler.
Page generated in 0.55362 seconds with 62 queries
