Garage cleanout. MORE ADDED 12/2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2009, 11:43 PM   #1
Jeep Thrills
Lumbermonkey/pedalpusher
Jeep Thrills's Avatar
Default Garage cleanout. MORE ADDED 12/2
Full set of new YJ Bestop flares, app 6 inches wide. Rear flares are marked for CJ also. $200 or best.
Sold. More parts added. White YJ half doors and 2 sets of door pads, one set carpet/vinyl, the other set is plastic. I have 2 black driver side upper frames, both with bad windows. also, one black passenger upper with a good window. $150 or best. Sold....gone.
Safety Speed Cut model H5 panel saw. Not sure of age, but it's in very good shape. Great for ripping or crosscutting plywood, paneling or foam board without damaging the edges. $1200 Like this one. http://www.sears.com/safety-speed-ma...&blockType=G11
[COLOR="Red"]
1973 small block Chevy rebuildable core. Engine code CKW. No knocks, just smokes like it needs rings. With 2 barrel intake and Rochester carb.$100 Ran when pulled a month or so ago.
1983 small block Chevy with Edelbrock performer RPM 4 barrel intake, no carb. Engine code URN. This was a good running engine when it was pulled YEARS ago, stored indoors. $250
Two AMC 304 V8s. One has bent valves, the other the oil pump drive sheered off. Good cores for a rebuild. $150 for the pair.
AMC 20 rear, 3.48 gears open diff, 2 piece axles. $100
Dana 30 front, 3.48 gears . no knuckles, no shafts. $100
Carb for YJ 4.2 Sold
Washer reservoir and pump for YJ. Sold
Distributor for YJ 4.2. Sold
Door latch pins for YJ. Sold
Jeep Thrills is offline   Reply With Quote
Old September 20th, 2010, 02:31 PM   #2
cerial
Direct Drive FTW
cerial's Avatar
Don't plan on being back in Michigan till thanksgiving. Replacing the body (steel tub from WO and using the good windshield/hood/grill is still the choice at this point) is not scheduled until late 2011. But I will give you a bump.
Old September 20th, 2010, 02:33 PM   #3
cerial
Direct Drive FTW
cerial's Avatar
Seems like good items to bring to that swap meet.
Old November 14th, 2010, 04:00 PM   #4
Jeep Thrills
I still need some front brake rotors and bearings for a dana 30,some one-piece shafts for an AMC 20,an HEI distributor for a small block Chevy.
Old January 13th, 2011, 06:44 PM   #5
bakeradam
im interested in the fuel cell any chance you ever make it to west Michigan?
thanks adam
616 560 3990
bakeradam is offline   Reply With Quote
Old January 13th, 2011, 08:01 PM   #6
Jeep Thrills
thanks adam
616 560 3990
Very rarely. I might meet you somewhere in the middle, though.
Old August 18th, 2013, 10:41 AM   #7
Jeep Thrills
Bump. Parts added.
Old August 19th, 2013, 07:22 PM   #8
Jeep Thrills
Beezow Doo-Doo Bumpitybump-bump-bump
Old August 20th, 2013, 05:39 PM   #9
Jeep Thrills
bump
Old August 20th, 2013, 07:13 PM   #10
Jeep Thrills
I also have some sweet-ass Firestone All Terrain recaps, circa the early 80's. Complete with natural siping , and with shallow tread technology. Roll F.A.T. at the Mustache Run , or just do some hot laps around your trailer park. Set of 4, $75.
Old August 21st, 2013, 01:15 PM   #11
michigan maniac
michigan maniac's Avatar
What size are the firestones? And have any better pics of the shallow tread technology?? I have a cj gear box, if you still looking for one
Old August 21st, 2013, 02:51 PM   #12
Jeep Thrills
The tires are 30x8x15. Gimme $130, you can keep the wheels too. I don't want to have to peel these turds off the rims
ID:	109640   Click image for larger version
Old August 22nd, 2013, 07:53 PM   #13
Jeep Thrills
bump
Old August 23rd, 2013, 08:28 PM   #14
Jeep Thrills
I'll trade everything but the SSC saw for a gas tank to fit a 1974 Jeep CJ5.
Old August 24th, 2013, 08:31 AM   #15
Jeep Thrills
Saturday Bump.
Old August 26th, 2013, 06:24 PM   #16
Jeep Thrills
Monday bumpski.
Old August 27th, 2013, 05:48 PM   #17
Jeep Thrills
tuesday bump
Old August 30th, 2013, 06:52 PM   #18
Jeep Thrills
Friday bump.
Old September 1st, 2013, 08:47 AM   #19
Jeep Thrills
Sunday bump
Old September 3rd, 2013, 07:16 PM   #20
Jeep Thrills
Tuesday bump. Wheels going to scrap soon.
Page generated in 0.34441 seconds with 84 queries
