| Home | Register | iTrader | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Store | Photo Gallery | Chat |
Thread Tools |
#1 |
"The Situation"
94 sonoma. posessed Gauge cluster
Goin down the road.. tach starts "'bouncing" a little bit but the Speedo jumps from 30-45 and i think i was doing ABOUT 35 ? any ideas on what would cause this ?? im wondering if the tail housing could have some grime in it causing that to bind ?? Im not sure..
#3 | |
Shenanigans!
x1238 People come into Murrays all the time with this problem and it usually ends up being the battery or a charging system problem Once in a while it turns out to be the ECM though... but that's pretty rare. Run to Murrays and get an on-car test
![]() -Jeremy |
#4 | |
"The Situation"
.. Maybe ill be taking it up there this week and having them check it again. unless they rent that equiptment out in their tool rental.ANyone on here got a VAT-40 laying around ? |
#6 |
Does it do this on a decel? I would check and clean the IAC port. Usally when a IAC motor goes bad you get random stalling and high rpms. Just a random stall can be that the passage is plugging up restricting the idle air.
AWK |
#7 | |
"The Situation"
| Thread Tools | |
