94 Tracker Sputtering after puddles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2009, 08:36 PM   #1
spazbrevik
Default 94 Tracker Sputtering after puddles
I have a 94 Tracker that bogs down and sputters after I hit any decent size puddle. I have checked the air filter after doing this and it is dry. I have also put a new cap, wires and rotor on it and although that did make it run better it did not affect the water issue. I saw in one of these post someone mention fuses under the hood, I am not sure if this would affect anything? Any ideas of suggestions on what I might need to do or look at? Thanks
spazbrevik is offline   Reply With Quote
Old April 8th, 2009, 09:46 PM   #2
scottie
Eye candy
scottie's Avatar
please define hit and puddle :)
Old April 8th, 2009, 10:00 PM   #3
spazbrevik
Hit meaning drive through it at anout 30 mph and puddle being about 20ft in diameter and from 6in to about a ft deep.
Old April 8th, 2009, 10:09 PM   #4
scottie
Eye candy
scottie's Avatar
drive slower
Old April 8th, 2009, 10:11 PM   #5
spazbrevik
Any ideas that don't involve changing the way I drive?
Old April 8th, 2009, 10:15 PM   #6
scottie
Eye candy
scottie's Avatar
Seal up fuse box in Tupperware container, same with computer (but make sure it won't overheat), Dielectrical grease on all connections, Seal things up with RTV, etc.
I'd just drive slower through deeper water
Water wings are for posers
Old April 8th, 2009, 10:26 PM   #7
spazbrevik
Thanks for the input. Maybe if I go fast enough the I will just skip across the water instead of ot flying up under the hood.
Old April 8th, 2009, 10:31 PM   #8
booblinker
Sore and Tired 24/7
booblinker's Avatar
Make sure you don't have any cracks in the coil too.
Old April 8th, 2009, 10:34 PM   #9
spazbrevik
Coil? Where would that be located at? I am pretty clueless when it comes to this type of stuff.
Old April 8th, 2009, 10:44 PM   #10
scottie
Eye candy
scottie's Avatar
its the metal looking box with a wire out of it that goes to the distributor (black/red round thingy on the back side of the head near the firewall), Its the thing that has a "spark plug wire" going to it, but its not a spark plug.
Old April 8th, 2009, 10:51 PM   #11
spazbrevik
Ah yeah I knew that. Sorry not that familiar with wroking on vehicles. ( as if you couldn't tell) I am better with sleds and small engines. Thanks for the suggestions.
Page generated in 0.20543 seconds with 56 queries
