Good local diesel mechanics? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2009, 06:08 PM   #21
shredder70
Chillin with the top off.
shredder70's Avatar
I have worked on a few of these strokes and the valve cover harness plugs on the inside of the cover come unattached and intermittently fire the injectors. VERY common problem. I would take the cover off, plug the harness back in and then run an injector buss test on it and it will probably solve most if not all of your problems, if not save you a couple hundred bucks. Good luck.
shredder70 is offline   Reply With Quote
Page generated in 0.19817 seconds with 26 queries
