Banshee Problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2009, 02:05 AM   #1
NSJIMJEEP
Default Banshee Problems
I am confused shitless about my quad.
its a 2005 yamaha banshee with FMF fatty pipes and power core two silencers, i have it jetted at 260.
The other day i was riding around, and it was running great......but today i went to ride and it runs like shit, its starts, but it wont let me rev up past a certain point....
I have checked the cables, and cleaned the carbs tonight, now it hardley wants to run at all. im LOST,
any suggestions?
thanks, jim
NSJIMJEEP is offline   Reply With Quote
Old April 8th, 2009, 02:48 AM   #2
blownexploder94
Todd
blownexploder94's Avatar
is it just jetted wrong for this cold temp.
Old April 8th, 2009, 05:15 PM   #3
Spence1986
SlowBalt SS
Spence1986's Avatar
Send a message via AIM to Spence1986
Running out of gas?
Spence1986 is offline   Reply With Quote
Old April 8th, 2009, 05:20 PM   #4
B
NINJA DEALER
B's Avatar
check the T.O.R.S. (throttle override system) the housings on top of the carbs, and also check the parking brake switch on the clutch lever. they tend to stick and wont let them rev beyond a certain point. or if neither one of those you could be jetted too lean for cold weather, does it backfire? pull the plugs make sure they are not white. or light colored. they should be a dark brown to be safe. also check the compression on both cylinders make sure you did'nt melt a ring and are running one one cylinder, all these things are common on banshees.
B is offline   Reply With Quote
Old April 8th, 2009, 05:23 PM   #5
special k
special k's Avatar
that jetting almost sounds a little lean durning warm weather for your pipes. i have toomey t-5's which are comparable to fatty's and i am running 280's and it runs great from 45-90 degrees.
Old April 8th, 2009, 05:49 PM   #6
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
x2 on brake switch let me see if i can find the write up
Old April 9th, 2009, 10:13 AM   #7
Cartman
Can't lose with 42s
Cartman's Avatar
Eliminate TORS (if you haven't already) and ride it again.
www.bansheehq.com
Cartman is offline   Reply With Quote
Page generated in 0.22227 seconds with 44 queries
