TJ lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2005, 08:59 PM   #1
Cougar123
Default TJ lift
I want to lift my tj 2" and put better shocks on it. What is the best kit to buy?
Cougar123 is offline   Reply With Quote
Old November 21st, 2005, 10:26 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
The best 2" setup would be the OME (Old Man Emu) replacement springs and shocks. But it's spendy.
A 2" budget boost (spacers) and any decent pair of shocks will do. If you put the budget boost in, then use a ramp or similar method to determine optimal shock size, then you can get a lot of flex for cheap.
At a charity event a few years ago, an otherwise stock TJ with a 2" budget boost and front swaybar disconnects ramped over 600 on a 30* ramp, which was better than many of the heavily modified rigs. It beat many of the other TJs there, and proper shock length helped it.
Old November 21st, 2005, 10:53 PM   #3
biohazardbill
Guest
Posts: n/a
A 2" budget boost is the way to go it is cheap and effective... if your going to spend tons of dough might as well spend it lifting it higher than 2 inches because if your like most people... 2" will only last so long before you want to go higher.
Old November 21st, 2005, 11:20 PM   #4
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I always tell people... if they are only concerned with 2" of lift... go with a BB. If they are looking for better ride, and better flex... step up to a ~3" lift kit.
JcrOffroad
Zoom Zoom!
Page generated in 0.19444 seconds with 35 queries
