camshaft for 351w efi - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 6th, 2009, 09:57 AM   #1
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
Default camshaft for 351w efi
trying to figure out what cam i can run. I have a stock 351w efi, I run the sandunes all summer and it's my daily driver, it is also has a mas air sensor, I heard that make a difference
ATOMIC_BADBOY is offline   Reply With Quote
Old April 6th, 2009, 12:39 PM   #2
frdboy
frdboy's Avatar
Do you know is it a roller cam or not?
Is the motor all stock?
Old April 6th, 2009, 12:59 PM   #3
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
If it has mass air it should be a roller motor.
fordlovinfarmer is offline   Reply With Quote
Old April 6th, 2009, 01:21 PM   #4
frdboy
frdboy's Avatar
It should be but I have seen a few that were not.
Old April 6th, 2009, 07:47 PM   #5
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
year?
pre 96 you may be able to run the E303 cam, i may be wrong on the part number, its been a long time.
wait, its got a MAF, you will need some sort of chip or programmer.
Old April 7th, 2009, 05:42 AM   #6
ATOMIC_BADBOY
Shake n Bake
i'm not sure if it is a roller cam or not how would i figure it out? i do have a jet perfomance chip in it
Old April 26th, 2009, 02:39 AM   #7
Jrod-13
poser wheeler
The E303 will work fine, especially being a MAF motor, it can adapt to some pretty serious internal changes..
Jrod-13 is offline   Reply With Quote
Old April 27th, 2009, 06:58 PM   #8
ATOMIC_BADBOY
Shake n Bake
don't you have to run a stahl converter
Old April 28th, 2009, 05:14 PM   #9
sandguy356
bronco built for fun
sandguy356's Avatar
You don't HAVE to run a stall, but to get full use of the cam, then you should have one.
sandguy356 is offline   Reply With Quote
Old April 28th, 2009, 05:57 PM   #10
TurdBronco
A cam change isnt going to do you much good if thats all you are changing on a stock motor.
Old April 29th, 2009, 12:45 AM   #11
shifty_85
2 low for fat hoes
shifty_85's Avatar
Send a message via AIM to shifty_85 Send a message via MSN to shifty_85
cam with E-fan intake and exhuast plus your chip on top of all that. do all that and you'll see some good power. just the cam you wont see that much.
what RPM do you normal use for the sand that will tell what cam you need. when your looking to buy a cam it will say power range 3,000-6,000RPM or 500-4,000rpm etc. and depending on what your looking for power now would be 500-4,000rpm or if you have a stall converter you can run the high rpm one 2,000 or 3,000 and up.
hope i helped ya out some.
shifty_85 is offline   Reply With Quote
Old April 29th, 2009, 10:46 AM   #12
Broncoholic
Guest
Posts: n/a
Go with an E & a light stall 1800 rpm or shorter tires 31 max.
Old April 29th, 2009, 06:30 PM   #13
TurdBronco
The Powerband on an e303 is 2500-5500. Its a waste on a stock head/intake motor. They don't make power past 5k rpm. The stock cam is good. Spend money or time upgrading other things. Underdrive pulleys or roller rockers for instance.
Check this link out http://www.alternativeauto.com/techt...ips_50.html#q2
Old April 30th, 2009, 06:00 PM   #14
ATOMIC_BADBOY
Shake n Bake
thanks guy's I will deffenitly take all of this into consideration, right now everything on my engine is stock so i will have to do some other upgrades first. My RPM's are mostly between idle and 4,000
Old May 1st, 2009, 12:36 AM   #15
SammySmalls
SammySmalls's Avatar
Try this:
http://www.compcams.com/CAMQUEST/
I did it for my 401 AMC, and its friggin nuts.
SammySmalls is offline   Reply With Quote
Page generated in 0.37561 seconds with 68 queries
