The latest project that is taking too long, a Jeep JK looking tube car - Page 22 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2010, 12:25 PM   #421
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Originally Posted by 95geo View Post
I has a gas pedal!
For your welder or your buggy?
Old August 17th, 2010, 04:36 PM   #422
95geo
newbie
95geo's Avatar
Both now!
Just when I thought I was done welding aluminum, I spent another day doing it....
Old August 21st, 2010, 12:43 PM   #423
fabguy01
hammer down grabbin gears
fabguy01's Avatar
Originally Posted by Skooter_Built View Post
I wish I had a set of Treps
Tires: FEELER 35" maxxis trepador - Great Lakes 4x4. The largest offroad forum in the Midwest
fabguy01 is offline   Reply With Quote
Old August 21st, 2010, 02:01 PM   #424
95geo
newbie
95geo's Avatar
Radials..... and 35's.... COMPLETELY different than the comp versions which are only 37's and 40's.
I want to see some more pics of what you're working on.
edit: After searching, I cant find what I was looking for... Didnt you post up some pictures of that rear axle in your avitar?
Old August 21st, 2010, 08:41 PM   #425
kkodet
kkodet's Avatar
Been checking out your build again. You've got mad skills Bryce. This is looking really good. Keep up the great work!
BTW, those pipes are sweet. You could make some serious dough in the hotrod market.
Old August 22nd, 2010, 12:05 PM   #426
fabguy01
fabguy01's Avatar
I used to work for Ross Hoek building Pro-2's for CORR,WSORR,TORC full time but with the economy the way it is he is'nt selling alot of em so i just help out once and a while. I didnt post any pics before all the pics i have are old school photos. the trepadors i have are from a friend who still races. I dont know how scanning will work maybee i,ll give it a shot one of these days
Old August 22nd, 2010, 12:48 PM   #427
95geo
newbie
95geo's Avatar
Ok, I must have a bad memory then...
So, these rear axles... I know they get heat treated but I'm wondering if you have seen if it's common to heat treat them after all of the brackets and tabs are on or they just heat treat the tubes and center section?
Old August 22nd, 2010, 01:59 PM   #428
fabguy01
fabguy01's Avatar
the way we do it is to have the snouts and brackets welded onto the tubes, and the center section and brackets welded as much as possible. then they are hardened to 32-34 rc. after hardening we would finish weld the 3 pieces together. after finish welding we built a massive fixture for stress relief. the rule of thumb for stress relief is for the part to be at 900* for 1 hour per inch of material thickness so the thicker the material that your fixture the better ours was mostly 2" crs this allows the part to be stress relieved to come up to temp way before the fixture has time to heat up and move.
Old August 22nd, 2010, 02:52 PM   #429
95geo
newbie
95geo's Avatar
Great info, Thanks!
I dream of fully heat treated and stress relieved axles some day..... The problem being the fixtures will cost as much or more than just the axle!
Old September 1st, 2010, 09:22 PM   #430
95geo
newbie
95geo's Avatar
It's getting closer.... Just a couple things left.
Got rid of the too big band saw and got something better sized for the shop.
It should be a nice upgrade from the $200 special that's been on its last leg for a while now.
Just a couple more tools to upgrade/buy and then it might be time to keep an eye out for a 4020 VMC.
ok, I'm dreaming a little bit there but maybe some day!
I'll get some "almost finished" pics up before the teardown.
Old September 10th, 2010, 06:26 PM   #431
95geo
newbie
95geo's Avatar
That's what's left.... It's going to feel really wrong to take it all apart.
Hopefully the driveshaft parts will be in next week so I dont have much of a hold up. At this point I have no idea how long it's going to take after it's painted but if it's anything like a full body build, it should be a couple weeks to a month at most.
Old September 11th, 2010, 01:11 AM   #432
95geo
newbie
95geo's Avatar
Looks like a pro mod to me.... Too bad I missed the boat by about 2 years...
Old September 11th, 2010, 01:43 AM   #433
creeping death
I'm that guy.
creeping death's Avatar
very nice!
you have a lot of welding to do!
Old September 11th, 2010, 07:35 AM   #434
Looks good Bryce. Oh, you don't have any headlights.
Old September 11th, 2010, 07:43 AM   #435
Tab
Tab's Avatar
Are those bolts there just for mock up? Or are they really short Kleco's or something?
Old September 11th, 2010, 09:16 AM   #436
95geo
newbie
95geo's Avatar
Those are just some m6's in there for the initial fit and placement. Once it's welded and warped, the holes will get opened up for m8's. That helps so the holes don't have to be any larger than they need to be. That skid plate will be a stressed member so it needs to fit nice and snug.
Old September 11th, 2010, 11:22 AM   #437
Tab
Tab's Avatar
Thats cool. I was just thinking from a rock snag perspective. Looking good though!
Old September 11th, 2010, 11:39 AM   #438
95geo
newbie
95geo's Avatar
I hate countersunk fasteners so I'm just going to use a standard bolt and stover nut with the head of the bolt taking the hits. When one gets torn up too much, it'll just get swapped out. If one gets mangled to the point you cant get a socket on it, I'll just cut the head off. It's worked pretty well in the past so I'm going to see how it works for this setup. I might have to weld it all up if it looks like it moves too much when the winch pulls on it.
Old September 11th, 2010, 12:01 PM   #439
fabguy01
fabguy01's Avatar
you may want to move your pcm,im not sure about the GM units we were running FAST units and we had issues with them getting hot and not working but they were fine after it cooled down.
Old September 13th, 2010, 10:38 AM   #440
95geo
newbie
95geo's Avatar
I thought about the ECM location but I dont think it's going to get any more heat than where it gets placed in factory vehicles. In my trailblazer the ECM is located roughly between the radiator and the alternator. I have no doubt that it's seeing close to a couple hundred degrees at times and where I have it on the firewall it should have more airflow than in the OEM location. I may wrap the headers or put in some heat shields if it looks like it and the interior are getting too hot but for now, I'm just getting things done, I can always change them later.
The teardown has begun!
Page generated in 0.36350 seconds with 85 queries
