Drivetrain tuck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2006, 12:31 AM   #1
Pre4runner
Bike Dude
Pre4runner's Avatar
Default Drivetrain tuck
I've thought about lifting the drivetrain on my toyota pickup... once saw a write up on it... can't seem to find it tonight. Does anyone have pics or now of a write up... ideas?
Old June 1st, 2006, 08:15 AM   #2
Well, one thing to do would be to look at some of the project vehicles in the Pirate4x4 Toyota board. They recently made a stickied thread of all the project buildups there.
Project Blu does a really nice lift/flat belly.
Rick's quasimoto build is also nice. (same guys that build Blu)
Really, you need to figure out how high you want to go, and what you want to do with the crossmember for the t-case.
Most people I have seen don't even bother messing with the engine mounts, they'll rotate just fine to accomodate the rear lift.
So its basically raising the T-case mounts to as high as you want to go. If you want to go full flat belly, then you'll need to clearance the floor, I believe.
Right now, I'm running a front range offroad t-case center section, with arms I built for it. I can raise it with additonal spacers under the ends. But I'm going to redo the mount to look like the one in rick's quasimoto build. my expereince with the FROR style, is that will the bushings at the frame end, I get a lot of vibration(although it helps control drivetrain torque quite well).
Hmm, actually I bet I know the write up you saw.. http://www.4x4wire.com/toyota/tech/drivetrain_lift/
Old June 1st, 2006, 07:26 PM   #3
Pre4runner
Bike Dude
Pre4runner's Avatar
Yea one of my biggest questions was just about the engine mounts, i couldn't find any pics or anything telling what they had done with them. ONe looked like it was raised but the photo wasn't clear.
I'll have to look through thsoe builds, i was checking some out last night but gave up.
Old June 1st, 2006, 09:14 PM   #4
I think they have some good pics of the engine mounts in project blu, with the t-case lifted 3 inches and stock engine mounts. Its not bad at all..
Old June 1st, 2006, 11:46 PM   #5
Pre4runner
Bike Dude
Pre4runner's Avatar
those are some good wright ups... i just tried searching the site last night didn't look actually. and the link to 4x4wire was the one i had seen before.
thanks
Page generated in 0.39421 seconds with 38 queries
