briggs flywheel removal/no spark - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Other Stuff > The Great Outdoors
The Great Outdoors Guns, Cannons, Fishing, Camping, and other fun stuff
Old March 27th, 2009, 12:42 AM   #1
ChevelleSSLS6
For Sale: AMC 360ci v8
ChevelleSSLS6's Avatar
Default briggs flywheel removal/no spark
Before I get started, I considered putting this into a tech section, but nothing seemed 'general' or 'small engines'. So, I guess it fits in "and other fun stuff" since these little buggers are fun to wrench on.
1960s? briggs 2hp horizontal shaft engine... on a edger. New spark plug from previous owner, didn't start with him and he gave it to me. I thought I'd look at the points (I think that's what they're called) and clean them to see if I can get some spark going.
First, I need to remove the small 'starter pull ratchet mechanism' (located on crank just in front of the flywheel) somehow, and I'm not sure how to go about this... if you have done it without any 'special tools' let me know.
as for flywheel, I have used gentle heat and gentle prying... about 15 seconds of 'gentle' propane heat and a really big screwdriver gently 'tugging' at the back of the flywheel got it loose on a 5hp vertical shaft I parted out over the winter.
With that vertical shaft engine I parted, the 'ball bearing ratchet mechanism' just came out really easy and fell apart. That's probably what happens with most small engines when left outside for about 5 years.
Thanks,
Matt
ChevelleSSLS6 is offline   Reply With Quote
Old March 27th, 2009, 09:57 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
Thanks,
Matt
First, the ratchet has a special socket, but you don't need it. Just use a really large pipe wrench and find a way to bar the engine from turning over. It unscrews the same direction it ratchets...to the left if i remember right.
Second, i recomend a gear puller to pull the flywheel.
Heat and a hammer can work, but the potential to damage the cast flywheel, magnets, or something else, is kinda high.
Page generated in 0.16802 seconds with 29 queries
