need trans+transer case help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 26th, 2009, 10:26 PM   #1
shifty_85
2 low for fat hoes
shifty_85's Avatar
Send a message via AIM to shifty_85 Send a message via MSN to shifty_85
Default need trans+transer case help
im going to make my truck from 2WD to 4x4 im going to get a 78 or 79 donner truck put the 44 up front use the coil buckets and coils get about 8" of lift get a leaf kit in the rear to match. the one prob im running into is the trans n transfer case
less than 3,000 miles ago i had my trans rebuild 4R70W 2wd. i was wonder if i could swap a tail shaft or put an adapter on to throw the transer case out of a 4x4 verison of my truck on? or do i have to get a 4x4 4R70W with the transfercase?
any help would be great thanks alot guys!!
shifty_85 is offline   Reply With Quote
Old March 27th, 2009, 07:08 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
less than 3,000 miles ago i had my trans rebuild 4R70W 2wd. i was wonder if i could swap a tail shaft AND put an adapter on to throw the transer case out of a 4x4 verison of my truck on? or do i have to get a 4x4 4R70W with the transfercase?
either of those will work
Old March 31st, 2009, 07:53 AM   #3
shifty_85
2 low for fat hoes
shifty_85's Avatar
just got news i would have to drop the trans to take the output shaft out. i cant just get the tailshaft and adapter....wish it was that easy!!!! DARN i dont wanna drop this trans again its a PITA!!!
Page generated in 0.23712 seconds with 32 queries
