2003 dodge ram - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 23rd, 2009, 09:55 AM   #1
adamant
adamant's Avatar
Default 2003 dodge ram
i have a dodge ram and i shimmy down the high way and wondering what it could be i just had both wheel bears changed. could it be the tie rods or ball joints? just wondering if any one would know. i know i shimmy could be caused but an out of balance tire or bent rim. i will take me truck in to get my tire rotated and make sure the tires are balanced.
adamant is offline   Reply With Quote
Old March 23rd, 2009, 04:01 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
sounds like a good place to start. also if you have a floor jack pick up each front wheel about an inch or so off the ground by the lower control arm so as the jack doesn't interfer with the tire. grab the tire top and bottom and see if it can be moved in and out. also pry up on it to have someone watch for a worn ball joint while prying
Yetti
Old March 23rd, 2009, 05:46 PM   #3
shredder70
Chillin with the top off.
shredder70's Avatar
I have seen this a bunch of times. COULD be when the rotors were removed a piece of rust fell down between the hub and the rotor and it is cocked on there. Good luck.
shredder70 is offline   Reply With Quote
Old March 29th, 2009, 01:27 PM   #4
kloock959
kloock959's Avatar
solved yet? did you have a shimmy before these bearings were changed?
kloock959 is offline   Reply With Quote
Old April 15th, 2009, 10:06 AM   #5
adamant
adamant's Avatar
yea my tires were out of balance i think. i rotated them and go tthem balanced the other day. i still have a little vibration but i think that could be because my ball joints and tie rods might be going bad.
Old April 15th, 2009, 03:02 PM   #6
PavementPounder
PavementPounder's Avatar
Well, when you start a thread for that, don't call it "2003 Dodge Ram". You have two threads named that already.
Name the thread title according to the actual issue. It will get confusing and you'll get less responses since you won't get the attention of people who are experienced with your problem (because they won't see the problem in the Forum Index).
Page generated in 0.29033 seconds with 41 queries
