vehicle pranks... - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2009, 07:50 PM   #21
cj7on44's
cj7on44's's Avatar
get a bunch of zip ties and putt them on the rear drive shaft and leave them long so they will hit some thing
cj7on44's is offline   Reply With Quote
Old March 22nd, 2009, 08:44 PM   #22
BlooMule
Old School
BlooMule's Avatar
Install a cheap car alarm, and don't tell him.
-rw-rw-rw
Old March 22nd, 2009, 08:56 PM   #23
curt1656
Praise the lowered
curt1656's Avatar
Loosen the lug nuts, cut the brake lines, acid in the gas tank. That's what I do to my friends. (If I had any left)
Old March 22nd, 2009, 08:56 PM   #24
L4CX
Out for the Summer!
L4CX's Avatar
I saw a Guy on Americas Funniest Home Videos do it. I thought it was funny. I really like the Paper Shred in the Vent idea. I would suggest Paper hole punches instead (Or Glitter). Those things are a pain to pick up. You could always hook it up to the lights.
L4CX is offline   Reply With Quote
Old March 22nd, 2009, 09:01 PM   #25
supersamikc
Yooper
supersamikc's Avatar
Send a message via AIM to supersamikc
get an electric firework squib and hook it up to the battery then when he starts the car it sounds like an explosion under the hood....(dad does firework shows)
supersamikc is offline   Reply With Quote
Old March 22nd, 2009, 10:34 PM   #26
RockyMTN05
Cadillac pimpin
RockyMTN05's Avatar
Send a message via AIM to RockyMTN05
Originally Posted by TJ SKWIG View Post
99 chevy blazer... no electric fan... i thought of that too.. that'd be the best
are you and bob going to attempt this on Steve?
RockyMTN05 is offline   Reply With Quote
Old March 22nd, 2009, 10:40 PM   #27
masterbeatty
masterbeatty's Avatar
get a temp control for an electric fan. set it somewhat low. when the car heats up it will click the relay and since it wont get that cold it will stay open. im sure you could run 2 relays in there to make it work.
Old March 22nd, 2009, 10:42 PM   #28
methodx55
methodx55's Avatar
Send a message via AIM to methodx55
meh, thats too much for just a prank, just loosen the lug nuts, sit back, and watch
methodx55 is offline   Reply With Quote
Old March 22nd, 2009, 10:44 PM   #29
masterbeatty
its 5 wires maby. 20 mins. if its a friend then the goal isnt someone bein hurt.
Old March 22nd, 2009, 10:48 PM   #30
methodx55
methodx55's Avatar
haha but that just makes it better
Old March 22nd, 2009, 11:17 PM   #31
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
take his driveshaft. he'll never notice.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old March 23rd, 2009, 01:02 AM   #32
cglenn
Change the sound of his horn too. That'd be cool if every time the horn went off his car would yell something out. Or to scare the crap out of him, hook up a 3 piece set of Nathan air chimes/ or similar.
cglenn is offline   Reply With Quote
Old March 23rd, 2009, 08:12 AM   #33
masterbeatty
hook up a cheap air horn under the dash and make it go off there.
Old March 23rd, 2009, 08:20 AM   #34
adam_in_48060
adam_in_48060's Avatar
Drill a hole through the middle of a potato. Then jam a whistle in one end of the potatoe. Finally, shove that potatoe inside of your victim's car exhaust pipe. Make sure the whistle is facing the outside. When your victim starts the car up and drives off, he will keep hearing a whistle and wonder what is going on.
adam_in_48060 is offline   Reply With Quote
Old March 23rd, 2009, 09:04 AM   #35
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Put flour in defrost vents.
IFS SUCKS is offline   Reply With Quote
Old March 23rd, 2009, 09:11 AM   #36
IFS SUCKS
I like trees
IFS SUCKS's Avatar
Originally Posted by 92comanche4x4 View Post
just put trans fluid in the vacume lines works great smokes so bad
A friend of mine bought a a piece of shit talon for 200.00$ Took a washer bottle with pump ran lines to upper intake hooked toggle switch to said pump,filled washer bottle with trans fluid.Instant spy hunter smoke screen.
Old March 23rd, 2009, 09:48 AM   #37
Mr Toes - R.I.P.
November 7, 1958 - July 22, 2011
Mr Toes - R.I.P.'s Avatar
Cut a bike inner tube then tie one end off and hose clap it to the tail pipe throw it under the car. when he starts the car the exhaust will start filling the inner tube and somewhere down the road thinner tube will fill up and pop. Should scare the shit out of him, and more than likely he will stop to see what happen and when he see's the inner tube he will grab it to pull it off his tailpipe and burn his hands...
Wire an M-80 to a turn signal and place it behind the grill infront of the radiator. when he turns on the turn signal it should blow the grill out and bust the radiator at the same time....
Throw sardines on the intake manifold....PU
Put a small amount of anthrax on the steering wheel....
Leave the guys car alone, thats grounds for a fight..
Mr Toes - R.I.P. is offline   Reply With Quote
Old March 23rd, 2009, 10:06 AM   #38
pumpshop4
USMC
pumpshop4's Avatar
A bunch of us used to pull all sorts of pranks on each other. We only had one rule. Never mess with another mans vehicle.
pumpshop4 is offline   Reply With Quote
Old March 23rd, 2009, 10:16 AM   #39
kiddd2
kiddd2's Avatar
A friend of mine took a junk window and broke it, then rolled down his buddies drivers side window and put the broken glass from the junk window around his car. The guy thought his car was broken into and used plastic for a window for 2 months in the middle of winter. He finally realized it wasn't broken when he took it to the shop to get it fixed.
kiddd2 is offline   Reply With Quote
Old March 23rd, 2009, 10:23 AM   #40
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Rice Krispies or Sand also work great.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Page generated in 0.48099 seconds with 82 queries
