wierd to start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2006, 06:34 PM   #1
going-strong
'96 360 sport 4x4
going-strong's Avatar
Default wierd to start
96 ram, 4x4, 1500
whenever i go to start the truck, i turn the key to "on" all the lights pop on (like they are suposed to), then when i turn it to "start" the is a delay (about 1 second or 1.5 seconds) with nothing, then it will crank and fire up...every once in a while you have to drop it down to neutral to get it to crank...the other day i could not start it in either one, started playing with the shifter and finally got it to start...ever since then, i do not need to press the brake pedal in order to shift into gear...the only thing i could think of was the neutral safty switch, which i replaced today, with no improvement on the truck...any help would be greatly appreacated
TIA
going-strong is offline   Reply With Quote
Old May 30th, 2006, 06:37 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Brake-park interlock switch?
Old May 30th, 2006, 06:45 PM   #3
going-strong
'96 360 sport 4x4
is that the techniqual name...im reading in my haynes manual, and i dont see anything about it
Old May 30th, 2006, 07:00 PM   #4
GreaseMonkey
Pew pew!
It's something like that I think....Haynes doesn't usually use very technical terms though.
Old May 30th, 2006, 07:08 PM   #5
going-strong
'96 360 sport 4x4
thanks, im gonna keep looking and if u think of another name for it, let me know
Old May 30th, 2006, 07:56 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Sometimes they call it the Shift Interlock switch.
Lemme check mitchell
Old May 30th, 2006, 08:09 PM   #7
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Well...in 1994 they have 2 park/neutral switches.
One located in the PCM (center of dash) and the other located at the rear left side of the trans.
Page generated in 0.23730 seconds with 44 queries
