several problems 95 explorer - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2009, 06:02 PM   #1
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
Default several problems 95 explorer
key fob not working, every time i plug in my alarm fuse it goes off and the key fob will not shut it off, unlock the doors or do anything.
Starter not engaging flywheel. i want to say the flexplate is stripped out beyond use, but if you've ever changed one thats the last thing you want to say has anyone had experience in changing them out on these things? id like it over with fast and easy.
wipers only work on High. my guess is a bad MF switch.
Highbeams have a bad relay. they get the smallest bit muddy or wet, i have to replace them. looking for a solution.
No horn. who makes a decent horn? i would like to install one.
my bumpstops seem to only allow like 6" of travel, if i remove a big 4" block in them will it affect anything on the street? (pix to come of said block)
also would like to cut off any un necessary parts in front.
any help/advice would be great
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old March 20th, 2009, 09:20 PM   #2
shredder70
Chillin with the top off.
shredder70's Avatar
sell it and buy a gm.
shredder70 is offline   Reply With Quote
Old March 20th, 2009, 10:36 PM   #3
Yota Bill
why would he want more problems then he already has, and at a higher cost??
remote=make sure batteries in remote are good, then reprogram it (sorry, dont have the procedure available, but call the dealer and they may tell you how to do it)
starter=pull the starter off to verify the flywheel is damaged..it may be just the starter...with the starter out of the way, though, you can easily see the teeth and spin the engine over by hand to check the whole ring gear
wipers=work on high, but nothing else, yes, replace the multifunction switch...think of a blower motor resistor, its setup similar
relay=dielectric grease
horn=its a horn, pick a parts store and buy one
bumpstops=any change to the factory suspension will affect it in some way..but doubt it hits the bumpstops very often during normal street use anyway...
and the last one...all depends on what you mean by "unnecassary"...after all, it doesnt need fenders, grill, or a hood to run and drive....
Old March 21st, 2009, 12:00 AM   #4
starter is brand new, ive used it 3 times, it was skipping a bit, i think the ring gear just finally pooped.
as for un-necessary things, theres a hook on my A-arms see in the pic.
as for bump stops..LOOK AT HOW FREAKING LONG THEY ARE!
Old March 21st, 2009, 01:27 AM   #5
beedle4
beedle4's Avatar
You alter those bump stops much and you will start tearing up your CV shafts real quick...
Old March 21st, 2009, 02:21 AM   #6
i was thinking of cutting them down an inch and a half at most
Old March 21st, 2009, 09:32 AM   #7
Broncoholic
Guest
Posts: n/a
Default HaHaHa
That would work
shredder70
["sell it and buy a gm.']
I thought Ciro was Ford Country. Who would want a General Mess from a bankrupt Govt. owned auto maker
Old March 21st, 2009, 06:50 PM   #8
hahaha
Old March 24th, 2009, 04:36 AM   #9
Shotgun
I only wheel with boats.
Shotgun's Avatar
so you buy the GM yet?
Old March 29th, 2009, 01:00 PM   #10
ILLICIT4x4
ILLICIT4x4's Avatar
I have all the parts you need and will need for it....If you wouldn't of ripped me off on that $200 I would have gave you a whole truck load of parts for it...
ILLICIT4x4 is offline   Reply With Quote
Old March 29th, 2009, 01:14 PM   #11
pm sent ryan
Page generated in 0.34887 seconds with 56 queries
