EAGLE SHORT BLOCK 408 SBC 9 hrs on CL & SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2009, 05:37 PM   #1
1twisted1
1twisted1's Avatar
Default EAGLE SHORT BLOCK 408 SBC 9 hrs on CL & SOLD
NO TRADES!!!
Need CASH THAT RIGHT $3000.00 worth of part for $1000.00
***********************This motor has 50 miles on it but needs going though, I dropped a oil line and now you should replace all the bearings. THAT IS IT BLOCK JUST NEEDS BEARINGS REPLACED!!!*********************************
Balanced Eagle ROTATING ASSEMBLY 408 Cast Steel Crank, SIR I-beam Rods, KB +30cc Dish pistons, Damper,flywheel & Block
Comp Cams, Hydraulic Roller Tappet, Advertised Duration 270/276, Lift .495/.503
Cloyes GEAR DRIVE
ARP Pro Series Cylinder Head Stud Kits,
ARP Balancer Bolt Kits,
ARP Main Bolt Kits,
ARP Oil Pump Stud Kit,
Edelbrock Victor Series Mechanical Water Pump Std Rotation
Moroso Oil Pump and Pickup kit, High Volume / Standard pressure
Moroso 7qt Street/Strip Oil Pan
Moroso Oil Pump Driveshaft,
Edelbrock Victor Series Valve Covers
Fel-Pro Performance Composite Valve Cover Gaskets,
Timing Pointer, Billet Aluminum, Black Anodized,
Adapter, Oil Filter, No Bypass, Aluminum, Black Anodized,
Spark Plug Wires, 409 Pro Race, Spiro-Wound, 10.4mm, Black
K&N X-Stream Air Flow Assembly
Power Master Starter High Torque
1twisted1 is offline
Old March 22nd, 2009, 11:14 AM   #2
1twisted1
1twisted1's Avatar
Wow
Anybody?
Old March 23rd, 2009, 06:50 PM   #3
1twisted1
1twisted1's Avatar
ttt
Old March 24th, 2009, 09:56 PM   #4
1twisted1
1twisted1's Avatar
Can't Beat This Deal!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old March 26th, 2009, 01:12 AM   #5
1twisted1
1twisted1's Avatar
bump
Old March 26th, 2009, 06:41 AM   #6
acenho
so this may sound dumb but it doesnt run? it needs to be rebuilt after it is bought? I am looking for motor but I can rebuild the one I got, I want one that works? Does this one?
acenho is offline
Old March 26th, 2009, 03:23 PM   #7
1twisted1
1twisted1's Avatar
No!! this is for the short block (from the heads down) But you could NOT rebuild a motor with these part for less than 3000.00
Old March 27th, 2009, 11:25 PM   #8
1twisted1
1twisted1's Avatar
ttt
WOW NOBODY!!!!!!!!!!!!!!!!!!!!!!!!!! Not even a lowball offer????????
Old March 28th, 2009, 03:04 PM   #9
pitbull2332
pitbull2332's Avatar
$600 ?
pitbull2332 is offline
Old March 28th, 2009, 07:32 PM   #10
1twisted1
1twisted1's Avatar
little too low
Old March 29th, 2009, 12:43 AM   #11
dmcjeep
dmcjeep's Avatar
Buy this motor and these heads I am thinking you would have one bad ass ride.
http://www.greatlakes4x4.com/showthread.php?t=128251
dmcjeep is offline
Old March 29th, 2009, 09:41 AM   #12
Rich Misiak
How about $700.
Rich Misiak is offline
Old March 29th, 2009, 01:40 PM   #13
1twisted1
1twisted1's Avatar
DEAL OF THE YEAR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
$850 lowest I'll go come and get it or I'm just going to sell as parts again.
Old March 30th, 2009, 05:50 PM   #14
1twisted1
1twisted1's Avatar
Last chance before I put in on CL for $850 also
Old March 30th, 2009, 06:05 PM   #15
IDIeselman
IDIeselman's Avatar
Why not throw a set of bearings in it and sell it for $1500 as a runner?
As simple as it is most people are afraid to put bearing in.
IDIeselman is offline
Old March 30th, 2009, 06:09 PM   #16
Broncoholic
Guest
Posts: n/a
Default `
2X If the bearings are gone does the crank need to be turned again? Oil pump gone too. sounds scary, If it was a Ford OK
Old March 31st, 2009, 01:36 AM   #17
1twisted1
1twisted1's Avatar
Just simply don't have the time at the moment to fix a motor I do not need, I'm knee deep in the diesel conversion. My Priority one is getting the burb done for the summer and I do not think that if I throw a set of bearing in it I will sell it any faster.. And no the crank does not need to be turned and the oil pump is still good.
Old March 31st, 2009, 07:58 PM   #18
glenns-garage
Default 406
Do you have pictures of the bottom end without caps?
glenns-garage is offline
Old March 31st, 2009, 09:38 PM   #19
1twisted1
1twisted1's Avatar
not a good one. Will get some good pics of the bottom end tomorrow and post them
Old April 1st, 2009, 08:22 AM   #20
1twisted1
1twisted1's Avatar
well that's That nine hours on CL and it Sold!!!!!!!!!!!!!!
Page generated in 0.34467 seconds with 83 queries
