400ex Camshaft journals questions?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2009, 10:55 AM   #1
dune coon
do work
dune coon's Avatar
Default 400ex Camshaft journals questions??
I dropped a valve on my '04 400ex last weekend, I pulled the top end apart and have a couple of questions.
1) The camshaft and rockers operating the exhaust valve on the drivers side are jacked up - I think it might be a lubrication issue. Is oil supplied to the cylinder head on both sides of the engine, or just one??
2) There appears to be a small amount of aluminum shavings built up on the side of the camshaft rotation - There are no bearings supporting the middle of the camshaft, only at either end. Therefore, is this normal? Can I re-use the head?
Does anyone know answers to these??
dune coon is offline   Reply With Quote
Old March 20th, 2009, 04:02 PM   #2
jeepguy74
jeepguy74's Avatar
there should be oil port on both sides of the head IIRC however 9 cant remember if it is independant of eachother or if it goes to one side and passes across to the otherside ...
i would mic. it and see if it is within spec..
i f you do reuse it i would drop the head in a solvant pan and soak it for a day ot 2..either way if you find a used one or reuse yours soak the hell outa it and blow it out
ebay has tones of them lol
Old March 20th, 2009, 10:41 PM   #3
dune coon
do work
dune coon's Avatar
i see that. it looks like I need a camshaft, valve(s), piston, etc. this sux!!
Page generated in 0.19667 seconds with 32 queries
