Ranger stalling - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2009, 09:52 PM   #1
kp99xj
kp99xj's Avatar
Default Ranger stalling
94 ranger 4.0 with a 5 spd stick. The gf called today and said it stalls when ever she lets the clutch out and can hardly even shift into gear. I have not had a chance to look at it until the this coming weekend. Also the trans fluid level is full and was changed with last oil change. new cluth last year. I am just wondering what might cause this and what to look at.
kp99xj is offline   Reply With Quote
Old March 19th, 2009, 01:00 PM   #2
deathbypsi
Brian R.
deathbypsi's Avatar
Look for a massive vac leak or check the IAC solenoid on the upper intake. The one on my 99 crapped out a while back and wouldnt let it idle below 2k.
Old March 19th, 2009, 04:37 PM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
check the parking brake
Old March 19th, 2009, 08:05 PM   #4
bikerted86
sounds like a clutch issue if it doesnt want to go into gear. Make sure the clutch master is full of fluid.
bikerted86 is offline   Reply With Quote
Old March 19th, 2009, 08:16 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
Yea maybe low on clutch fluid? Did the slave cylinder get changed with the clutch, I know those are really common to leak. And if its low, it like the clutch is an on/off switch, so if you don't have enough throttle its gonna stall out cus its like dropping the clutch.
Old March 19th, 2009, 09:00 PM   #6
Fraser
Fraser's Avatar
X2
Page generated in 0.21655 seconds with 41 queries
