Ways to bend 1/4 or 5/16 plate 90 deg? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2009, 08:37 PM   #1
Ready4Wheelin
Ready4Wheelin's Avatar
Default Ways to bend 1/4 or 5/16 plate 90 deg?
Anybody have a good way to bend 1/4 or 5/16 plate 90 degrees in their garage without fancy equipment? I've got this fabrication idea in my head that would require such a bend in a piece about 2.5 feet long. Can I heat it with a torch, or would that take any temper out of the steel? I have a small steel layout table I can weld to if that helps. Thanks!
Ready4Wheelin is offline   Reply With Quote
Old March 18th, 2009, 08:52 PM   #2
brimy311
Smells like a Fork Liftis
brimy311's Avatar
uhh, good luck. I recommend angle iron.
JcrOffroad.com
Like us on Faceook!
Old March 18th, 2009, 09:10 PM   #3
sanman
sanman's Avatar
clamp it to the table and my buddies wife could set on it guarantted to bend!
sanman is offline   Reply With Quote
Old March 18th, 2009, 09:12 PM   #4
Yeah, you're talking a lot of tonnage to bend that. If you're using mild steel you won't hurt it by heating it but I doubt you can heat it evenly enough to get a decent looking consistent bend over the entire length.
Old March 18th, 2009, 09:17 PM   #5
Ready4Wheelin
Yeah, I didn't think I would be able to. Thought I would ask though, just in case somebody had a crazy trick.
Old March 19th, 2009, 09:05 AM   #6
trailrail302
Im going FAST!!!
trailrail302's Avatar
take it to a fabshop with a press it should by pretty cheap to have one bend put in it. That will be a pain in the ass to do by yourself....and like WhiteRhino said it will be hard to bend evenly with a torch.
trailrail302 is offline   Reply With Quote
Old March 19th, 2009, 09:14 AM   #7
95geo
newbie
95geo's Avatar
eisen steel or something like that in richmond has bent a lot of work benches for us and they are very reasonable... you might contact them...
or if you're set on doing it yourself then you can make a few cuts with a plasma or really steady torch in a straight line where you want the bend to be and only leave about 3-4" of actual material to bend and then you can just fill the cuts in with weld and smooth it out with a grinder...
Old March 19th, 2009, 05:49 PM   #8
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
IMO that would be the best solution without a press brake or the heat and beat.
If it was shorter I could bend it for ya. I don't have a long large v die to brake it in and I'm to lazy to make one. LOL
Old March 19th, 2009, 06:05 PM   #9
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
That size material for 90* bend......I'd just weld 2 pieces together.
Old March 19th, 2009, 06:10 PM   #10
04PSD
aka Langford
04PSD's Avatar
exactly what I was going to suggest. I got frustrated as hell trying to get a good straight bend on some 1/8" steel, but I was only working with a few C clamps, a wood work bench and a bigass hammer. 1/4" or 5/16"... no way in hell.
04PSD is offline   Reply With Quote
Page generated in 0.88727 seconds with 53 queries
