Hydro vs. Electric Your thoughts... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2005, 11:47 AM   #1
KaiserJeep
boogidy boogidy boo
KaiserJeep's Avatar
Default Hydro vs. Electric Your thoughts...
ok, I have an electric already and will be putting on a bigger winch. So lets hear it, Hydro vs. Elec... and WHY!!
KaiserJeep is offline   Reply With Quote
Old November 21st, 2005, 12:56 PM   #2
Grandman
do i look old !
Grandman's Avatar
Well im not impressed with the Mile marker winch .
Now if your talking a real HYD winch ran off a pto pump there is nothing to compare . The Ramsey HYD winch is nearly unbreakable . They have been the king of winches in the towing world for ever .
You can pull none stop until the cows come home , nothing to heat up .
The mile marker i think can be a good winch , problem iv seen is heat because its off the power stearing pump . No wheres near enough fluid volume nor is it filtered as it should be .
Mile marker set up on an older Med duty truck stearing pump i think would work well , add a small reservoir for extra volume and a HYD generic fliter then ya got somthing .
At the very least put on a cooler and run the stearing fluid through it for a Miler marker winch .
Last but not least . If you put your ride in water and it shuts down for any reason , your done with a HYD where as the electric will pull you back above water to get things restarted .:gman:
Old November 23rd, 2005, 04:10 AM   #3
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
well put G-man :gman:
GMCsonoma94 is offline   Reply With Quote
Old November 23rd, 2005, 11:04 PM   #4
smasheromalley
smasheromalley's Avatar
I think bottom line is if you're stalled for any reason the hydraulic is as dead as your engine.
Course you probably wont get far when stalled with no charging and only one battery either.
Ive got a junk ramsey 8k cause it was cheap like me
Old November 29th, 2005, 06:20 PM   #5
kevp77
I break it!
kevp77's Avatar
Send a message via Yahoo to kevp77
I carry a jump pack where ever I go. Electric!
kevp77 is offline   Reply With Quote
Page generated in 0.19680 seconds with 38 queries
