Transmission/T-Case Problem?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2009, 10:28 AM   #1
malibuman82wgn
Default Transmission/T-Case Problem??
Here's the story guys...Got a truck and whenever I used to drive it in the summer (maybe once or twice a month), I would have to add 1-3 quarts of ATF...Was going to take it out one day, checked the fluid, was decent, added a 1/2 qt anyways and started taking it home...Drove for about 25 miles, ate lunch, came back out, about a 1/2 qt. underneath the truck...Continued my trip home, about 40 miles later it just stopped moving, truck wouldn't grab a gear...Brought it home came back 2 days later and there was a LARGE puddle of ATF underneath it, most likely all the fluid in there...Truck wont grab a gear and makes a grinding noise when i put it in park...So is that a T-case problem or trans problem or niether?? Anyway I can check?? I was guessing a t-case problem but not sure...Any help I would appreciate it...Thanks
malibuman82wgn is offline   Reply With Quote
Old March 18th, 2009, 12:06 PM   #2
Broncoholic
Guest
Posts: n/a
Get a 5spd OD Yours is toast
Old March 18th, 2009, 06:20 PM   #3
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
year, make, model, engine, trans, ?
all of this information would be very helpful.
Old March 18th, 2009, 07:50 PM   #4
malibuman82wgn
94 f250 4wd 351w e4od
Old March 19th, 2009, 06:44 AM   #5
04 EDGE
04 EDGE's Avatar
sounds like the front pump seal. very common on these.
Old March 21st, 2009, 11:19 PM   #6
malibuman82wgn
please delete...thanks guys
Page generated in 0.24761 seconds with 41 queries
